Go Back   Avid Pro Audio Community > Pro Mixing > Avid Pro Mixing General Discussion
Old 02-14-2018, 05:54 AM
JasonSoundDesigner JasonSoundDesigner is offline
Default Metering Issue: -23dB tone reading as-3LU in Insight
I noticed my levels weren't matching up so I've been investigating.
I set up a -23dB sine wave with Avid's Signal Gen on a mono audio track. I have Izotope Insight set up on my master fader and it's reading -3LU/-26LUFS (Momentary Max). PT metering set to 'Linear'.
It's my understanding that -23dB is equal to 0LU/-23LUFS and I can't work out where I'm getting the -3dB drop.
I've tried having Insight on the track insert instead of the master and have the same issue.
I have recorded a clip of the -23dB generated tone and imported the file in to Izotope RX and it's giving a similar reading.
What am I missing...?
See screenshots attached
Old 02-14-2018, 08:48 AM
crizdee's Avatar
crizdee crizdee is offline
Default Re: Metering Issue: -23dB tone reading as-3LU in Insight
Route the mono track to a mono master and see if its the same! if mono routed to stereo master then you have the -3db pan law
Chris
Producer, Engineer,
Slow Readers Club_Build A Tower top 20 UK album charts
www.ukmastering.com
PT10.3.10 Mountain Lion HD6 accel Magma PE6R4 Control 24 MacPro 12 Core 3.46ghz UAD-2 Octo x2. Manley Vari-Mu, Manley Massive Passive, SSL VHD, ADL600, Grove Tubes ViPre, Tube-Tech CL-1B. Hafler TRM active monitoring.
Old 02-16-2018, 05:20 AM
Thanks, just tried that. Doesn't seem to make a difference though..
FS: Izotope Insight Essential Metering AAX WolfieCAL Buy & Sell 0 08-25-2015 05:48 PM
Help! Metering issue.... trigoe macOS 2 05-28-2014 07:53 AM
Metering Issue abre Pro Tools 10 0 01-10-2013 01:14 AM
Help with monitoring/metering issue PTGuy Pro Tools TDM Systems (Mac) 3 12-07-2005 02:14 AM
Possible insight into harness issue Greg B 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 08-01-2005 11:02 AM
