Old 06-01-2008, 06:42 AM
Dowski Dowski is offline
Default 7.4.2 and Reason still not compatible?
I had to remove my DigiReWire.dpm to get PT to boot up (just like with the earlier release). Still Reason is the only program so far not working as a plug. Has this not been fixed yet? Anyone else still having this problem?
Mac Pro 2 X 2.8 GHz Quad-Core, 12 GB RAM, Digi 003,
10.5.3, 7.4.2
Old 06-01-2008, 07:47 AM
Anthony Jr.'s Avatar
Anthony Jr. Anthony Jr. is offline
Default Re: 7.4.2 and Reason still not compatible?
I did a clean install of Leopard come 7.4.2 release time. No problems between Reason & PT here, and I've been using it every day since the release.
2018 18-Core iMac Pro / 64GB RAM / Mojave 10.14.3 / Protools 2018.12 / Apollo 8XP / Love
Old 06-01-2008, 07:59 AM
barstool719 barstool719 is offline
same here. clean install, no problems. 10.5.3/7.4.2/reason 3.05 (still used for compatibility)
did you:
-repair permissions
-delete preferences
-reboot
-try a new user acct
i7-860 / 12GB Kingston / Intel DP55WB / 500GB Barracuda / 1TB Deskstar W7x64
Focusrite Saffire Pro 40 / Pro Tools 9.0.3
Mics, Guitars, Amps, Basses, Drums, Keys
http://overtheeffect.bandcamp.com
Old 06-01-2008, 11:50 AM
I'll give all of these a shot. Thanks...
10.5.3, 7.4.2
Old 06-01-2008, 12:30 PM
also try setting your RTAS CPUs for one less than you actually have. (ie on a 4 core mac, use 3, on an 8 core use 7, etc) - I havent had ANY errors with PT and Leopard since I did this.
Old 06-01-2008, 08:39 PM
docscholl docscholl is offline
IT's just my 2-cents worth, but I've been having a long-running problem of not being able to get Reason to work on PTLE7.4.
The Reason people blame Digidesign, and the the Digi folks blame Reason.
Either way... all the other plug-in's work fine, except for Reason.
003+ Factory & Mbox 3
Apple powered by OS X 10.5.8:
iMac 2GHz Intel Core 2 Duo/4GB SDRAM (8.0.5LE)
PreSonus DigiMAX FS
Old 06-02-2008, 07:05 AM
Yeah I did some heavy experimentation removing, adding, updating, etc. this weekend and I'm still not having any luck with Reason (I've only been able to open in stand-alone -never as a plug in).I even went off one of the other current threads, removed propellerheads and melodyne folders, kept the digirewire.dps in the plug-ins folder, and as usual that file prevented me from even being able to open PT. That digiwire.dps has never worked on my rig. I should note that only Reason seems to not work (and not even show up as a selectable plug in). Kontakt, Reaktor, Guru, BFD2 and other programs that presumably (correct me if I'm wrong) use rewire protocols work totally fine on my rig and have for moths... Digi any ideas?
10.5.3, 7.4.2
Old 06-02-2008, 08:06 AM
DigiTechSupt's Avatar
ALL Rewire capable applications must be updated to their most current, Leopard compatible versions, especially Melodyne.
Doing so should fix the problem.
Avid Audio Tech Support
Support FAQ
Old 06-02-2008, 10:58 PM
MixBox MixBox is offline
Dowski, you are not alone.
I have a MacBook Pro 2.2 with 2GB ram and a brand new 003 Factory and I am going crazy trying to figure this out.
I seem to have the same error as you. Pro Tools will not boot with the DigiRewire plug-in in the folder. If you remove it, then it will boot fine. My standalone Reason 2.5 works perfectly, but is obviously not rewired to Pro Tools. I have a fresh install of Leopard 10.5.3 and fresh install of PT 7.4.2pr. I tried resetting permissions, trashing prefs, and burning purple goat feathers while chanting Pink Floyd lyrics... nothing works.
Trying to launch Reason Adapted on its own does not work either because of an error that says "Failed to locate and install Reason Engine, exiting". (Not sure if this needs PT's to be running correctly with rewire in order to work or not but will not boot before or after PT's is running right now.)
The version of Reason Adapted is 3.0.5 (build 674) Which is supposed to be fully Leopard compatible, so the last post is questionable. I don't understand what is going on.
Help, someone please, any rational ideas??????
MixBox
  • MacBook Pro 2.2GHz
  • OSX 10.5.6
  • 2 Gigs Ram
  • 003 Factory
  • PT 8.0
  • MPTK2
  • Grande Caramel Macchiato
Old 06-03-2008, 07:33 AM
My standalone Reason 2.5 works perfectly...The version of Reason Adapted is 3.0.5 (build 674)
sounds like you have two versions installed. that *could* be causing a problem.
Reason 2.5 compatible with ProTools V.8? musiquito 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 09-22-2010 03:23 PM
Pro Tools 8 and Reason 4.01 Not compatible? drdolla80 Pro Tools TDM Systems (Mac) 15 05-08-2010 07:41 AM
is Reason 4.0 compatible w/ Pro Tools 7.3.1 ? Angelo of Onello 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 04-13-2009 08:24 PM
OT - Reason is it compatible with Tiger? lampmusic Pro Tools TDM Systems (Mac) 3 06-22-2005 11:03 AM
Reason ? looking for good synth/ drum maching program compatible with 001. P. North East 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 03-31-2002 07:08 PM
