Old 03-13-2018, 11:14 AM
Juan Garcia Juan Garcia is offline
Default Workstation reset error
Hi guys!
I've got another intermittent issue with our S6. Sometimes, right after boot, we get this error message:
The system expected list failed to load. All connected workstations have been reset.
It's not ground breaking as we can reconnect once the computer is fully booted.
Why might that happen?
Best,
J.
Old 03-13-2018, 02:52 PM
creativecontrol's Avatar
Default Re: Workstation reset error
Greetings,
Please try deleting the Expectedlist.xml file (login as admin) located here:
Users : S6 Users: AppData Local...
Jeff
Jeff Komar
Solutions
S6 FAQ
MTRX FAQ
Old 07-29-2019, 06:58 PM
mschatzlein mschatzlein is offline
Jeff, this is not a fully-qualified path to expectedlist.xml, and indeed I can't find it in any folder under appdata/local
Old 07-29-2019, 07:18 PM
Sorry. Here you go:
C:\ProgramData\Avid\S6\
ExpectedWSList.XML
Note: ProgramData is hidden by default.
best,
Jeff
Jeff Komar
Solutions
S6 FAQ
MTRX FAQ
Old 04-22-2022, 02:32 PM
dopplah dopplah is offline
I am also having this problem, and the paths above are not valid for me. Where is the file that needs deleting? I'm on an S4 connected to MacOS Mojave 10.14.6. Power cycling has no effect.
"The system expected list failed to load. All connected workstations have been reset."
Old 04-23-2022, 05:06 AM
Note that you need to enable the view for hidden files in the Windows Explorer in order to see the root folder C:\ProgramData
Jeff
Jeff Komar
Solutions
S6 FAQ
MTRX FAQ
Old 04-23-2022, 12:37 PM
EddieJones's Avatar
The most common reason for this happening is the file gets corrupted after the Master Module is powered off without shutting it down first.
Old 04-27-2022, 12:29 PM
This worked, thank you! Indeed I was powering it down without doing a proper shut down. I will be better in the future.
Password Reset - Error ! HELP !!! 808 SQUAD Licensing & Accounts 6 03-03-2023 02:55 AM
Error -6090 Firewire reset BalanceMusic 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 05-19-2009 08:44 AM
ERROR # 6090 FIREWIRE RESET kabkrusader 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 09-19-2005 08:26 AM
RESET then PAGE_FAULT_IN_NONPAGED_AREA error- HELP GapeOne 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 9 03-03-2004 01:52 PM
002 reset firewire error Michael Cottrell 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 5 10-29-2002 01:35 AM
