Old 06-12-2014, 05:54 PM
soundista soundista is offline
Default Video Engine can't launch
I am troubled now cannot play a video truck without being able to load video engine.
The progress bar which I am going to load appears and becomes 100% in more than one minute when I turn on the check box of the video engine, but does not start even if then it passes for several minutes.
And the following alerts appeared after around ten minutes.
"Kernel extension is not from an Identified developer
The kenel extension at "/System/Library/Extensions/DeckLinkFrameBufferDriver.kext" is not from an
identified developer but will still be loaded.
Please contact the kernel extension vendor for updated software"
Is this driver made in Avid?
Answer myself. It's a Black Magic's driver.
I do not remember that I installed the driver, but QuickTime video format is DV.
So the session that imported the video truck of this format may require Black Magic.
OSX10.9.2 PT11.1.3 HD Native Mac Pro Black UAD-2 Oct
Old 07-15-2014, 04:52 PM
Default Re: Video Engine can't launch
I solved a Video Engine trouble myself.
I could not find a reason why video engine did not start.
However I found the method to run at last.
Therefore I use an Activity Monitor.
At first Pro Tools started, Activity Monitor shows Avid QuickTime Server does not work by red letter.
To force quit Avid QuickTime Server, double click the red letter and open dialog.
After quit the process of Avid QuickTime Server, restart the Pro Tools, not restart a OS.
That' all.
After the quit the process of Avid QuickTime Server have been freezed one time, Pro Tools can run Video Engine.
Video Engine Won't Launch in Pro Tools 11 haudio Post - Surround - Video 10 11-23-2014 07:57 AM
Waiting for the Video Engine to launch nicolasvandooren Post - Surround - Video 8 02-09-2014 02:32 PM
"Waiting for the Video Engine to launch" error mrhood Post - Surround - Video 0 07-25-2013 01:28 AM
Pro Tools 8 LE stalls at video engine launch Tommy Barth 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 10-13-2009 01:44 PM
Video Engine Failing to Launch palmer_jankens Pro Tools TDM Systems (Mac) 2 12-01-2008 02:40 PM
