Old 09-06-2010, 06:17 PM
JazzBum JazzBum is offline
Default :confused: Pro Tools HD playback thru Mbox/Mbox Micro?
Is it at all possible for Pro Tools HD 8.0.3 to playback through an old school Mbox? I have an Mbox micro that was hoping to use when I'm traveling to edit on flights and such... is that even possible since it's traditionally an LE device?
Also along those same lines... is it possible to connect an original Mbox for the same reasons? More specifically this time though, I am most interested in playing back through good speakers via the stereo outputs on the rear if I'm forced to work away from my studio.
Anyone out there that can point me in a good direction here?
Thanks.
Old 09-06-2010, 07:07 PM
Default Re: :confused: Pro Tools HD playback thru Mbox/Mbox Micro?
HD is not compatible with any LE interface. You need LE to use withMbox. Note that the original Mbox is not compatible with LE newer than 8.0.1, so a Snow Leopard machine needs to get a newer Mbox 2, Micro, Mini or 2 Pro and use 8.0.4.
Old 09-06-2010, 07:27 PM
CME CME is offline
Thanks.
As mentioned HD and LE interfaces require separate software. However the sessions created between the 2 are interchangeable. So you can easily work on a session created in HD on an mbox. But as stated the original Mbox has reached it's end of life, so an Mbox 2 would be a better starting point. And would include the PTLE software to use with it.
Dell T5810. Harrison Mixbus 32C. Haven't used PT since 2015 and never been happier.
FS: Mbox 2 Micro with Pro Tools LE 7.4 soul Buy & Sell 0 07-30-2013 08:54 AM
Pro Tools LE 8 with MBox 2 Micro = no audio playback mrmao 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 04-04-2013 05:46 AM
Pro Tools 9 What do I do with my Mbox 2 Micro danrocks Pro Tools 9 14 11-15-2010 05:53 AM
Mbox 2 Micro without Pro-Tools CaptainBlackSK4 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 4 08-06-2010 07:36 AM
Plugins and PRO TOOLS LE mbox 2 micro Digital Network 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 09-26-2008 11:22 AM
