Old 12-04-2019, 12:50 PM
oldsoul oldsoul is offline
Default PT Control App wifi port
Does anyone know what port is used to connect via Wifi for the iOS PT Control app? In my corporate environment I can't get EuControl to recognize the app. If I hardwire my iPad using ethernet straight to the computer it works. Also I tried creating a personal hotspot with my iPhone and connected that way through wifi and it worked. I'm just trying to get it to work with the companies wifi and thinking that that the port may be blocked for some reason.
Old 12-04-2019, 07:42 PM
EddieJones's Avatar
Default Re: PT Control App wifi port
Check the subnet of your computer and the iPad, they may be different
Old 12-05-2019, 05:43 AM
They are indeed different. Sorry I'm not an IT specialist. I assume they need to be on the same subnet?
Old 12-05-2019, 08:12 AM
EddieJones's Avatar
I'm afraid you'll have to speak to your IT dept. They may be able to pulg you into a different switch on the same subnet as the WiFi
Old 12-06-2019, 09:37 AM
Thanks, That will most likely be difficult. Can you tell me what port the Control app uses. I might be able to have them open that port up.
Old 12-06-2019, 09:41 AM
EddieJones's Avatar
It uses multiple and they change. It will never work on different subnets.
Old 12-06-2019, 09:48 AM
The other strange behavior is tried this at home and checked the subnets which do match and I can't get Control to show up.
Old 12-06-2019, 09:51 AM
EddieJones's Avatar
This could be different, are you sure you have 19.12 EuControl at home ?
Old 12-06-2019, 10:05 AM
Yes, just downloaded it.
Old 12-06-2019, 10:10 AM
EddieJones's Avatar
To confirm the Control doesn't show up in the left (All Surfaces) column in EuControl ? Try force quitting it or restarting the iPad.
Optimization says disable wifi- ilok needs wifi HughHM Pro Tools 12 10 12-21-2017 09:52 PM
wifi (iPad) control set up with s3lx [email protected] VENUE Live Sound Systems 3 11-22-2016 06:05 PM
MC Control Ethernet port issue RuffinMedia Artist Series 2 02-03-2011 04:44 PM
Enable Ethernet Port For Pro Control? RT60 Pro Tools TDM Systems (Mac) 6 10-26-2007 03:32 PM
USD and G-port-machine control? trakbytes Post - Surround - Video 2 10-31-2003 04:36 AM
