Old 01-20-2017, 02:54 PM
jyt jyt is offline
Default HP XW8400 DAE error -1115 was encountered
Hi here is my setup
HP XW8400 -windows 7 64bits- sas drive-8GB of ram
two core card pci-x
one accel pci-x
I get this DAE error -1115 was encountered message as soon as I put
core in pci slot 5 133mhz
core in pci slot 6 100mhz
accel in pci slot 7 100mhz
if I remove core in slot 6 and replace with accel, it's all good
just the two core is also working
if i skip slot 5, then i get the error
my conclusion, is if i trade one core for an other accel card, am I going to run into the same problem, does core-accel-accel run on an xw8400
anyone please!
Old 01-22-2017, 03:40 PM
Default Re: HP XW8400 DAE error -1115 was encountered
What exact version of Pro Tools? Did you run the installer using the Right-click>Run as Administrator option(you should for anything on windows 7)?
Old 01-24-2017, 11:35 AM
jyt jyt is offline
I'm currently running PT HD2 8.1.1 , currently is run great, I was just having this problem when I try to put in core-core-accel cards, two core won't work with one accel, but core+accel is fine, wondering if it's the third pci-x slot (7) that can be the problem, if problem is. I will eventually exchange one of the core for an other accel card, so I will be certain only then.
Old 01-24-2017, 11:42 AM
jyt jyt is offline
Also I initially had PT 8.05 install, that's my original DVD installer, but then when I upgrade to 8.1.1, it was absolutely a pain, but finally got it done, http://duc.avid.com/showthread.php?t=386385, so it is not a privilege problem at all, I'm always running thing as admin anyway.
Old 02-03-2017, 01:45 PM
Neil H Neil H is offline
If you are putting more than one core card in a system the second one has to be the last card so you need to put them Core>Accel>Core try that and see if it helps.
Pro Tools 2019.5 Ultimate
Windows 10 Pro
Join the Facebook Pro Tools Windows User Group
Old 03-11-2017, 02:36 PM
jyt jyt is offline
Yes I did try that before, core-accel-core but today I received my second accel card and insert it exactly like it should be core-accel-accel...result same problem, i'm gonna try to swap the two accel position, but just so you know slot 5 core, slot 6 accel, slot 7 accel, if that still doesn't work then I will try on my second xw8400 and see perhaps that's a hardware problem, perhaps the motherboard is starting to give away, because it seem that anything i put in slot 7 doesn't work, is there something to change in the bios, perhaps that can also be a problem. my bios is v.2.38
Old 03-13-2017, 10:44 AM
jyt jyt is offline
resolved my problem this morning, removing everything and starting from scratch, then I found out that the problem was simply a driver conflicting, was the midi interface motu driver, removed it and BANG! all good, YES I'm now HD3 on a old and great PC, all that for real cheap, love used stuff and it's much better for the environment and my mind
Old 05-27-2017, 12:33 PM
Cool to hear you got it working,
I have two old XW8400's too but I haven't used them for PT for a long time, I have a TDM rig consisting of PCIX core and 3x Accels in a Magma PE6R4i expansion chassis connected to a HPZ800 (Dual Quad Core Xeons and 64GB of RAM) that's working well and will be sticking with in my studio because I also have a large Pro Control surface too that only works with PT10.
Windows 10 Pro
Old 05-29-2017, 09:31 PM
If you have more PCIx slots, I have a core and 2 accel cards available. PM me
Dae error -1115 was encountered esuanzes 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 7 09-10-2012 11:42 PM
DAE error -1115 was encountered? Glasshousefields 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 04-21-2010 09:25 PM
DAE error -1115 was encountered Renan 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 7 10-16-2009 12:58 AM
DAE ERROR-1115 was encountered debardalo 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 17 10-07-2009 10:53 PM
DAE Error -1115 was encountered DJTMS 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 06-02-2007 08:35 PM
