Old 06-30-2009, 10:23 AM
soundmaster soundmaster is offline
Default Strike MIDI Region empty after reopening session
Hi there,
strange problem. I produced a piece in PT8cs3 with 6 Audiotracks,1 DB33 Instrument track and 1 Strike Instrument track. Saved, shut PT down, shut PC down, went off. Came back, started PC, opened the Song but every region of Strikes instrument track was almost EMPTY , just the very first note was there in some of the regions.
any idea anybody
(this never happened before)
PT HD 9.0.6/Win 7 pro SP1 64bit/Q6600/EMU1820m
PT 9.0.6/HP 8560w/ProFire2626+Octane
Old 06-30-2009, 11:06 AM
RussUK RussUK is offline
Default Re: Strike MIDI Region empty after reopening session
How did you create the Strike track?
Did you drag and drop the patterns or did you play notes to get each pattern to change?
I work with amazing people who do incredible things.
Founder of the Expert Sites.
Old 06-30-2009, 11:21 AM
Hi Russ,
thanks for lookin in
I created an instrument track, inserted STRIKE in A and recorded several takes (notes to change patterns), quantized start and end of notes. "ctrl d" only one region out of seven.
Until now I tried to reproduce this weird behavior but no "luck", everything working fine. Recreated the regions (could use my bounced mix to figure out) shut down everything opened again and all notes were there ??
Old 08-10-2009, 11:58 AM
andreŠs andreŠs is offline
Same thing happening here! After reopening a session some midi regions are empty - randomly. WTF? This is absolutely horrifying!!!!!!!
I am not using Strike. Happens on different tracks.
Right now I'm working on a very tight time schedule. I am heavily alarmed.
Anybody?
Old 08-10-2009, 12:03 PM
OK we need to be methodical about this.
Once you drop MIDI into tracks then it simply becomes a MIDI track, so what your saying is when you have an instance of Strike in a session that some of the MIDI data is missing from tracks assigned to Strike when reopened? If you answer is yes, can I ask you to check 2 things:
1. Are the missing tracks still in the region list?
2. If you import session data then do the tracks appear in the new session?
Old 08-10-2009, 12:12 PM
Russ, Thanks for the fast reply!
Just to be clear, I'm not the original poster. I'm NOT using Strike.
I have those issues within different midi regions on different tracks.
I have the problem that midi regions are "losing" their content after reopening (or whenever).
Unfortunately that happens randomly on different tracks.
PT8cs3, OSX 10.5.7, HD Accel5, 10GB RAM, 2x3 Quad-Core
Old 08-10-2009, 12:27 PM
soundmaster, Did you somehow resolve the problem?
I'm sweating...
Old 08-10-2009, 12:44 PM
So my questions still remain and perhaps identify to as a PT8 bug not a Strike bug, what happened when you looked into the 2 questions I asked.
The quicker you answer those the quicker we may find a solution.
Old 08-10-2009, 01:06 PM
To be quick:
1. I don't miss tracks or regions. I miss events in regions.
2. see above.
Old 08-10-2009, 01:13 PM
I did some tests.
The problem occurs after saving, closing and reopening the session.
I don't have to quit PT or restart the Mac.
Plugin settings disappear when reopening the session - PT 10.2 Luke83 macOS 0 07-27-2012 08:06 AM
Problem with reopening session saved in pt5 gbr8 Windows 0 06-04-2012 05:26 AM
Session layout not being remembered after closing/reopening a session/Pro Tools! DJ Hellfire Pro Tools 10 1 12-23-2011 12:05 AM
MIDI not playing correct patches when reopening session ThatDigiGuy MIDI 2 06-13-2009 11:45 AM
Help! Region bin empty !?!?! Allbaldo Pro Tools TDM Systems (Mac) 3 05-26-2006 08:50 AM
