Old 01-19-2016, 10:00 AM
genebackmusic genebackmusic is offline
Default MIDI recorded latency after playing with no latency
Hi folks I'm new here and thank you in advance for any help on this!
Here's my setup:
Mac Pro (Late 2013), 3.5 GHz 6-Core, 16GB Memory, OSX 10.10.5 (Yosemite)
Universal Audio Apollo Quad w/ Thunderbolt (Console version 8.4.1)
Pro Tools LE 12.4.0
Akai MPK261 MIDI Keyboard (Using Pro Tools preset #9)
This never used to happen to me before PT 12, but I've noticed recently that when I record any MIDI track (this is with my buffer setting at 64), the actual MIDI notes themselves appear to be recording late (as if I was playing with my buffer setting at like 1024).
So for example, as I'm recording a MIDI cajon track as an Instrument Track with my buffer at 64, it sounds like I'm playing with minimal latency. But then when I playback, the notes are very noticeably behind what I THOUGHT I was playing. Another example, simple quarter notes that I feel like I'm playing right on the beat, are being recording slightly behind the beat on my grid.
I checked my MIDI settings and the AKAI website to make sure that my keyboard firmware/settings were solid, as well as my UA console software. Everything is up-to-date.
Please help. Also please excuse me if this is a ridiculously simple problem to fix!
Old 01-19-2016, 01:07 PM
Default Re: MIDI recorded latency after playing with no latency
OK please, anybody?
Old 01-19-2016, 01:34 PM
Hannibal Lecter's Avatar
Hannibal Lecter Hannibal Lecter is offline
can you do it at 32 sample? as always, it's a good habit to check both visually and aurally. you can always nudge or sync to transient. But do turn on the ADC.
Old 01-19-2016, 01:51 PM
Hey Hannibal thanks for your reply. I tried 32 and it's still exactly the same thing. I've been recording MIDI for a long time and before I started noticing this weird glitch, I used to be able to record even at 128 with no problems with the final recorded MIDI result. Delay comp is also engaged.
Re: nudging, I usually avoid having to nudge at all since I play most of my MIDI with the intent on not quantizing in the end.
I have no idea what is causing this...
Old 01-19-2016, 02:02 PM
ChuckS ChuckS is offline
Do you have any plugs on the Master? That will mess with delay compensation in a few scenarios.
PT 2024.3 DP 11.31 VEP 7.x with various VIs
NI Komplete Audio 6 on HP Envy 8G i7 Quad Laptop Win11
MOTU 828es ADA8200 MTP-AV on HP Z2 G4 Xeon Workstation Win11
MOTU M4 on MacBook Air M2 2023 Sonoma.4.1
Old 01-19-2016, 02:11 PM
Hey Chuck thanks for your reply. I actually don't use a master track or bus since I normally bounce my mix and then "master" the stereo file in a separate session.
Something I forgot to mention, all of my live audio is recording/playing back just fine, for instance, my live guitar or percussion tracks. It's only the MIDI that's acting weird!
There's actually another MIDI related issue that's been happening lately as well (which never used to happen before, since even the days of PT9), but I wanted to get to the bottom of this thing first.
Old 01-19-2016, 02:14 PM
YYR123's Avatar
YYR123 YYR123 is offline
Originally Posted by genebackmusic View Post
Here's my setup:
Pro Tools LE 12.4.0
Wierd like really Deja VU all over again.
Let me guess Kontakt with Cuba library?
I had the exact same issue- but I had a Apollo Quad with FireWire...
Same deal, played a rhythm part via midi and got way out of sync.....never figured it out, I was moving away from the Apollo anyway
Daniel
Old 01-19-2016, 02:35 PM
No in this case I was using EastWest Storm Drum 3. But I also tried it with Kontakt and it's the exact same thing!
I don't think it's an Apollo thing because I like I said, this only started happening recently. I would venture to say that this has started happening in the last couple weeks.
Been recording MIDI with none of these issues for basically 5 years straight before this....ugh
At this point should I just buy an Avid support ticket and get it over with?
Old 01-19-2016, 02:36 PM
YYR123's Avatar
I noticed it around 12.2
Maybe a bit earlier than that actually, I can't remember exactly
Daniel
MIDI note Latency . . . live keyboard playing is a "little behind" The Zone 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 6 11-09-2012 05:33 PM
Delay or latency on recorded tracks DEEZGUYZ 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 11-07-2007 06:20 PM
Recorded latency with Mbox on Mac..!!! flintan 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 22 04-05-2005 06:21 PM
Hi- Problem- lots of recorded latency sinasl1 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 09-26-2004 05:09 PM
Latency When Playing back MIDI JSXtremist 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 6 11-12-2003 09:54 PM
