Old 02-24-2014, 05:11 PM
ThroughAGlass ThroughAGlass is offline
Default Overmodulation above -6 db
I recently upgraded to Pro Tools 10. I noticed that anytime I bring the level of anything above -6 it distorts. Any ideas why? Is this normal for pro tools? I know other DAWs don't distort until 0, so I can't imagine this would not be the case for pro tools. What am I doing wrong?
Thanks a bunch
Old 02-24-2014, 05:25 PM
sw rec sw rec is offline
Default Re: Overmodulation above -6 db
Are you sending a +4 signal into a -10 input maybe?
Old 02-24-2014, 07:53 PM
albee1952 albee1952 is online now
Nowhere near enough info
Old 02-27-2014, 02:49 PM
jeam25's Avatar
jeam25 jeam25 is offline
Hi
Just guessing ...Maybe your preamp or converter is clipping before going to your audio card ..But like i said just gessing ...because i dont know all the hardware youre using and the configuration ...
Maybe more info could help !
- Jesus Alvarado -
Keep the volume UP !
Old 02-27-2014, 03:52 PM
Craig F Craig F is offline
Not enough information but I will speculate that your system needs to be calibrated
PT11 System Requirements link http://avid.force.com/pkb/articles/C...m-Requirements
Thank you,
Craig
Old 02-27-2014, 06:59 PM
Bill Denton Bill Denton is offline
Is the term Overmodulation ever used in just an audio context? If so, what does it mean?
I'm familiar with Overmodulation from my AM radio days...in smaller markets we were not only DJs, we were also "transmitter operators", which meant we could get popped pretty hard by the FCC for something like "willful persistent overmodulation", but I've just never heard it used outside of a broadcast context...
X
Note that all opinions, observations, whatever, in this post are mine, unless I'm being mean or am wrong, in which case it's somebody else's fault. I do not work for Avid (their loss)...my only relationship with Avid is that of a customer (when I'm not too poor to buy stuff, like now)...and that hot administrative assistant...that's more of a "thing" than a "relationship" (that should keep them guessing for a while...)
Just rockin'...what more is there?
Bill in Pittsburgh
Old 02-28-2014, 07:23 AM
jeam25's Avatar
Hi
Tought this is a not "standard" description for a distorted signal it is a right definition .
http://en.m.wikipedia.org/wiki/Overmodulation
The OP is right .
- Jesus Alvarado -
Old 02-28-2014, 12:52 PM
Originally Posted by jeam25 View Post
Hi
The OP is right .
The OP is right
Well...not quite...
"... and distortion of the recovered modulating signal."
recovered modulating signal is the key phrase...
"recovered" is referring to the reception of the received signal, i.e. picking it up with a radio.
The audio signal itself is not distorted on the sending end. There is not any audio distortion at any point.
So, the OP was not quite right with his description.
The article mentioned "spurious emissions"...that is the cause of the distortion heard on the receiving end of the transmission. Basically, the broadcast signal gets "wrapped" in these "spurious emissions" which cause interference that results in distortion being heard, although the audio portion itself is not distorted.
And by the way...back in the day you could not call yourself a DJ unless someone had accused your entire radio show of being "spurious emissions"...
X
Bill in Pittsburgh
Old 02-28-2014, 06:16 PM
jeam25's Avatar
Hi Bill youre right,
I agree that in the article in a knowledge sense it is intended to be interpreted as a radio signal .
But in practice ; on this camp ( audio recording ), there are : transducers ( guitar ) , there are mediums ( mics ) and there receptors ( ears ) .
So this principle applies on recording too my friend .
The last phrase says :
"Although overmodulation ( distortion ) is sometimes considered permissible, it should not occur in practice; a distorted waveform envelope ( audio wave ) will result in a distorted output signal of the receiving medium ( mic , converter or ears , depends on how do you see it )" .
So here another article from " TriggerTone " :
Over Modulation
From Chace Audio
Over Modulation occurs when a signal, (be it from an acoustic source, such as sound recorded into a microphone, or an electronic signal passing through a console), is too loud for its intended target to handle. When this happens, the microphone or recording electronics' acceptable operating levels are exceeded, and the result is distortion.
Tags:
ANOMALY, RESTORATION
Related Terms: CLASH, CLIPPING, DISTORTION, HOT, INTERMODULATION DISTORTION, PEAK DISTORTION
http://www.triggertone.com/term/Over_Modulation
So if your point is that the OP not right on the correct interpretation you're maybe right as long youre are seeing it as a radio station view point . But we are not here radio stations or something like that ... so I know everyone here including you known very well what the OP means when he said " overmodulation " that is that distorted signal .
So I think is right ! And pleassure to talk !
p.d. " sorry for my english "
- Jesus Alvarado -
Old 02-28-2014, 07:32 PM
On this one I'll have to stick to my guns...You, my friend, are thinking like an audio engineer... Where you inserted "( audio wave )" in "... a distorted waveform envelope ( audio wave ) will result in ..." was incorrect...in AM broadcast you have essentially two waveforms...one, the carrier waveform (540–1610 kHz in the US)...second, the modulation waveform (audio between roughly 50 Hz to 7.5) hence their use of "waveform envelope", as the term refers to a wrapper for multiple waveforms...think of it in terms of a really long "Slinky" toy, which you have used to form a sine wave. The "Slinky sine wave" would represent the carrier frequency, while the actual "body" of the "Slinky" (the continuous circle part) would represent the modulating frequency...
Over Modulation
From Chace Audio
Tags:
On this one, the website wouldn't work for me (and I always try to look at "source" documents...even media I usually agree with will sometimes try to "fudge" things a bit.), so I'm not going to state an opinion on it...
Now where did p.d. come from? I've seen "p.s." for "post script", or literally "written after", but I've never seen p.d., does that abbreviation mean something in your native tongue?
"Modulate" means "change" which is why the term was originally adopted in broadcast: The modulating (audio) signal changes the carrier signal.
Which is in line with my original question as to usage of the term as it was being used by the OP. While I could see someone using, "Over Modulation occurs when a signal, (be it from an acoustic source ..." for a quick-and-dirty layman's explanation of distortion, he's wrong on two counts, not only is he misusing the word modulate, what he's actually describing is overloading an input stage.
But hey...it's Friday night...Does any of this really matter anyway? I've got my little miniature-dachshund-I-share-custody-of-with-my-ex-wife here to keep me company, along with two boxes of Girl Scouts "Thin Mints"...and that's a Friday night? God, I'm getting old...
X
Bill in Pittsburgh
fixing overmodulation in PT? anders Tips & Tricks 4 08-30-2000 12:02 PM
