Old 01-16-2021, 10:08 AM
Marsdy Marsdy is offline
Default S3 Soloing causes channel pans to centre bug?
This is strange one.
I’m wanting to solo multiple tracks that are selected in PT. Pressing option+shift on the Mac keyboard, then a solo button on the S3 on one of the selected tracks solo’s all the selected tracks as expected. But, and here’s the problem, it also centres the left pan of every stereo channel in the selection. It’s happening intermittently unfortunately. It’s occurring quite a lot though and I’ve actually seen the left pan centre in PT’s mixer many times.
....And a question for which I should probably RTFM. Is the option for plug-in windows to open automatically when selecting a track JUST a EUCON preference or is there a keyboard command in PT that turns this on and off? I ask because I keep selecting solos in PT along with shift or command or option+shift (not sure which yet) and suddenly a plug-in window starts opening whenever I select a track.
Dave Marsden
UK
Old 01-16-2021, 02:42 PM
Default Re: S3 Soloing causes channel pans to centre bug?
Shooting from the hip:
Problem 1-Cam't think of a reason for this to happen, so trashing prefs would probably be my best suggestion(this is always worth a try for any odd behavior, and this sounds odd to me)
Problem 2-almost certainly a setting in EUCON
Old 01-18-2021, 08:18 AM
Doesn't the 1st problem sound like hardware? Same problem others have run into with early units randomly centering pans (I think Bob K posted about a similar issue) - if multiiple tracks are selected and shift-opt held down when the problem occurs it would center all selected tracks.
http://www.richbreen.com
Old 01-18-2021, 05:16 PM
EddieJones's Avatar
I'm not sure about the first issue but will look out for it. The 2nd one is most likely the settings EuControl that control attentioning and then displaying plugin windows. Take a look at the general tab, turn off the open plugin option and see if thats it.
Old 01-20-2021, 01:19 AM
Thanks for the replies everyone.
I’ve just got to the bottom of the first issue and it’s a case of super-embarrassing user error. When I hit option+shift on the Mac keyboard + solo on the S3 I’m occasionally brushing against the rotary encoders on the S3 which is set to left pan. It takes the slightest touch! Duh.
Second issue: What I don’t get here is that engaging solos in the PT edit window with keyboard modifiers is enabling plug-in windows automatically opening on track selection in PT.
Dave Marsden
UK
Centre channel from Quad recordings Artis Post - Surround - Video 5 04-25-2019 11:10 PM
Problem with Centre and LFE channel SindriKara Post - Surround - Video 4 07-27-2015 04:57 PM
afl solo in centre channel? tomlowd Post - Surround - Video 1 10-11-2007 02:49 AM
afl solo in centre channel? tomlowd ICON & C|24 1 10-10-2007 06:42 AM
Send pans follow channel pans? woodshopsound Pro Tools TDM Systems (Mac) 2 10-14-2004 01:36 PM
