annoying bug with midi zoom
while using the midi zoom in/out, some clips are bigger than others
as a result, when the first clip reached the biggest zoom (while zooming in), all the others are not zooming in any more the same works for zooming out is there a way to set all the clips to the same wise so the zoom will do the same work on all midi clips ? (I have found that only the horizontal zoom in/out does the trick) mind you that the size changes can occur even while duplicating a midi clip. the new clip will be created with a smaller size... Last edited by rantaib; 09-29-2018 at 09:28 AM. |
Re: annoying bug with midi zoom
Also if you move a midi clip into a midi track from the clip list it automatically resets the zoom level, I wonder what the rationale behind this is
Brian Hudson |
MIDI - re-spell accidentals in Score Editor, and MIDI zoom | nhwinni | Pro Tools 9 | 4 | 09-08-2011 10:14 AM |
Very Annoying MIDI Issue | TreeDaddy | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 3 | 02-23-2010 10:46 AM |
MIDI I?O Reset This is soooo annoying! | Touchwood Studios | Pro Tools TDM Systems (Mac) | 0 | 09-17-2007 07:32 PM |
midi I/O problem still the same... very annoying | Anibal | Pro Tools TDM Systems (Mac) | 10 | 03-05-2007 09:45 AM |
SUPER annoying Zoom bug since 6.7 | Chris Coleman | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 09-27-2005 12:58 AM |
