Old 09-23-2018, 11:11 AM
bleachbro bleachbro is offline
Default 2018.7 Ultimate, Sierra, S3, PT| Control/Dock Crashing
I have had about 2 crashes per day under heavy use; I suspect it might relate to EuControl (latest versions and firmwares).
The only pattern I see is PT will unexpectedly quit for no consistent reason. Then, a few minutes later, EuControl quits...
Posting just to see if anyone has a similar rig and has seen similar crashes? Or I could be chasing something else but there is no apparent repeatability of this crash yet, that I can see...
Thanks in advance for any thoughts...
Old 09-23-2018, 11:38 AM
PhiBee's Avatar
PhiBee PhiBee is offline
I have the same install. The issu came from the S3 power connector that is a bit sensitive and tends EuControl to crash.
I stuck him so it could not move.
WIP house Prod - home studio
iMAC - Pro Tools Ultimate 2022.6 - RME Digiface USB - Audient iD22 - Behringer ADA8200 - Digidesign C|8 - NI KK A61
STUDIO PRO Post-prod
MAC Pro "Trash can" - Pro Tools HDX + Ultimate 2021.12/Avid C|24/S3/ProTools|Dock. Blackmagic.
Old 09-25-2018, 04:55 PM
abc1mce2's Avatar
abc1mce2 abc1mce2 is offline
Default Re: 2018.7 Ultimate, Sierra, S3, PT| Control/Dock Crashing
Windows machine here but I don't have the S3. I get crashes similar to yours I tracked it down a few to plugins but other times I believe it's Eucon or Dock related. Eucon / Dock iPad stays on after the crash for a few minutes and I have to wait several more minutes after that to start PT without restarting my computer. I think I'm going to disconnect and disable the Dock and Eucon and see if helps. Though I should mention my crashes are a lot less these days.
Sent from my SM-N950U using Tapatalk
What is more relaxing than Music?
Pro Tools Carbon for macOS 12.7.4
My HDX for Windows11.
Gigabyte Z490 Vision D - BIOS F21b
Intel Core I9 10850K Windows11 / macOS 12.7.4 Hackintosh / 32GB of Rams
Avid Carbon/HDX 2024.3 Ultimate - 8x8x8 HD I/O - PT Dock - PT Control - Artist Mix (1)
Universal Audio Apollo Twin|X - UAD2 Pci-E and Satellite USB Octo v.11.0.1 - SOLO 610 - Twin-finity
Bricasti M7 (2)
Lexicon PCM96
Neumann KH805 - KH310
Yamaha NS-10M
Avantone Mixcubes
Grace Design M905
Etc, etc, etc.
Dock Monitor control 2018.7 eucon master fader Jamie Mac Avid S1, S3, Dock and Control App 5 08-02-2018 07:31 PM
PT 2018.4 Ultimate bugs ? Glazik Pro Tools 2018 26 07-10-2018 11:56 PM
Pro Tools 2018.3 / 2018.4 crashing when switching window configurations matthewmkb macOS 0 06-27-2018 06:33 AM
S6 M10 v3.5 works with PT ultimate 2018.4 ? vudoo Avid S4/S6 3 05-30-2018 03:06 PM
Question: Sierra or High Sierra for PTHD 2018.3? johnnyv Pro Tools 2018 25 03-18-2018 08:30 PM
