Scrub Wheel in PT
I can`t figure out WHY Pro Tools use the wheel the way it does. In all the DAW that I tried so far, you turn the well it move, you stop moving it stop and it`s the same in forward or reverse. Why does PT need to make it complicated, I understand the scrub function and all that, but why not just default to a regular movement ?
Thanks
Your eyes can deceive you don't trust them , Mix with your ears |
Re: Scrub Wheel in PT
So what problem are you having with the scrub wheel? I can vari-speed scrub forwards and back, and switch it to variable speed shuttle mode. So what do you call "regular movement"?
Dell Precision 490 Workstation, dual 4 core 5355 Xeon, 16gb Samsung DDR2 ECC Ram - Windows 7 Ultimate - Nvidia GTX 650 - 3 x Internal WD Blacks - PT 2018.3 - Digi 002R - Original Mackie HUI - 3 screens - JBL Monitoring. Dell XPS 8700 i7-4790 - 24gb RAM - Windows 10 - Nvidia GTX 1060 6GB with Studio driver 546.01 - 2 x Internal Samsung 860 EVO SSDs, and MSATA card - Davinci Resolve Studio 18.6.4 - 3 screens - Blackmagic Speed Editor - MK1 Presonus Faderport - Canon C100 mk2 - Atomos Ninja 2 - Zoom H2n |
Thanks Wizzoboy for the reply and sorry for the delay, bussy in the Studio
What I call "regular movement" is just a quick forward and backward movement to place the playhead where I need it like in Cubase. In ProTools If I just spin the wheel nothin append I need to click on SCRUB but then I get a really SLOW movement I don`t need to ear the sound I just need it to be QUICK and RESPONDING Thanks again for your time
You need to use the wheel in Shuttle mode. An in-depth explanation of its' setting is on pages 621 to 624 of the reference manual.
And if none of the above helps, tell us exactly what you are using as a scrub wheel
Thanks for your time and help
I`m using a Mackie Control Original (See Pic) in both Cubase 9.5 and Pro Tools 2018 and all I need is the same basic fonction in Pro Tools that I get in Cubase At thre moment without doing anything else then turning the wheel I get about 2.5 mesure on Evry turn EZ and fast on the other end in PT I don`t use it at all Thanks again
I just tried 800% for Shuttle and 2000% for FF and I also de activate audio on playback ... No problem in Cubase but in PT my UAD plugins crash
Still I have audio and it`s still slow See Pic Also did ... Press Control+ 9 (Mac) on the numeric keypador Start+9 (Windows). But Still Nothing
Mmmm....might be a limitation of the Mackie Control. I use an original Mackie HUI and it has a dedicated Shuttle function.
pls make a weel working pro tools software | Shanti Monkey | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 6 | 09-02-2010 04:03 AM |
Spinning weel when in punch in rec mode...HELP !!! | miha78 | Pro Tools TDM Systems (Mac) | 2 | 06-27-2006 10:54 AM |
Scrub Tool (Scrub and extend region) | tsr2 | Pro Tools TDM Systems (Mac) | 1 | 03-07-2005 05:19 AM |
Mouse weel scroll support? | ricren | Pro Tools TDM Systems (Mac) | 3 | 09-10-2003 08:25 PM |
Nifty scrub selector doesn't work on Pro Control scrub wheel ???:eek: | Jules | ProControl, Control|24, Command|8 | 10 | 01-25-2000 10:52 AM |
