Old 07-12-2018, 10:15 AM
punchiest punchiest is offline
Default Line 1365 error at the end of a bounce
I am trying to fix this error for a fellow user.
Specs -
PT 2018.3 - Win 10
HP PC tower - 8GB ram
Focusrite Clarett 2
She is getting this error at the end of a bounce:
E:\code\222370\ProTools\NewFileLibs\FF\Audio\FF_Au dioFile.cpp Line 1365
Prefs - Trashed
2018 Reinstalled
Focusrite drivers updated
ASIO4ALL does not fix problem
Has anyone dealt with this yet?
Old 07-12-2018, 04:03 PM
The Weed's Avatar
The Weed The Weed is offline
Default Re: Crazy New Error during bounce
Is there a CD/DVD in a drive or a USB stick in a port? If so, remove and try starting PT again.
Demos: brucehayward dot com
SonoBus
Source-Connect: brucehayward
Options for Remote Direction
Old 07-13-2018, 03:47 PM
Nothing in the CD tray and nothing in the USB slots except the iLOK
Old 07-14-2018, 09:58 AM
john1192 john1192 is offline
may i ask, does this happen in both flavors of Bounce, Realtime and Offline ??
Macmini M1 8/512 -OS 12.3.1 and PT2022.4
Logic Pro X 10.7.4
RME BabyFace Pro
Macbook Pro july 2014 2.5ghz 16gb ram 512gb SSD - OS11.6.5 - PT 2021.3
Logic Pro X 10.7.4
RME BabyFace Pro
Old 07-16-2018, 07:43 AM
Default Re: Line 1365 error at the end of a bounce
Well....
I showed her how to do an old-fashioned "bus bounce" like we do on the HD3 TDM systems. That worked, but it leaves her with a WAV file and she needs to be able to make mp3s for her students.
This is oddly frustrating.
Old 07-16-2018, 07:54 AM
The Weed's Avatar
Just name and export the file as an MP3.
SonoBus
Old 07-17-2018, 01:04 PM
Any and all bounces result in the ERROR I posted. The only type of mixing that seems to work is a real-time bus record.
Old 07-17-2018, 03:46 PM
Bob L's Avatar
Bob L Bob L is offline
May be barking up the wrong tree here, but....
I see that the error references an "E" drive. That's not where PT is installed, is it? IT should be on the "C" drive, shouldn't it?
Bob
Without a song
The day would never end
Old 07-23-2018, 07:26 AM
PT is installed on C. This is why this seems weird. Her E drive has to be the iLOK, but E does not show up in explorer.
Old 09-26-2018, 10:35 AM
Please re-read the initial post on the thread before commenting.
Thanks!
PLEASE HELP !!! "FF-AudioProperty.cpp. line 33" bounce to disc error. Chris7514 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 12-24-2008 11:00 AM
error "FF_AudioProperty.cpp",line 33 when i bounce to disk jpf99 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 03-10-2007 09:08 PM
Can't Bounce-Assertion Line 33 Error-Tests So Far Making Music 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 04-17-2006 12:14 PM
Bounce to Disk Error:"CNeoIOBlock.cpp" line 164 Halessej 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 03-22-2006 11:38 AM
line 33 error (can't bounce to disk) Brian West 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 07-27-2004 12:10 AM
