Old 09-27-2014, 10:53 AM
WernerF WernerF is offline
Default Re: finally solved!!!
Hey tidalwave, can you tell me which power supply you bought. I think that I am having the same problem with slightly different symptoms. Is your chassis the PE6R4-I? I'm having trouble narrowing down which is the proper replacement PSU as Magma doesn't seem to carry the silent one anymore. I know that I can buy it from another source it's just that I can't seem to source the correct replacement yet. Thanks in advance for any info.
Old 09-29-2014, 04:52 AM
tidalwave tidalwave is offline
Default Re: PT HD stuck at "initializing hardware DSI" [RESOLVED]
Heyho!!
you can use any good PSU!
try to get one with enough ampere on the 12 volt rail...
I bought this one:
http://www.bequiet.com/de/powersupply/34
and it works just fine!
cheers!!
Old 09-29-2014, 06:55 AM
Thanks for the info!
Old 12-09-2014, 03:03 AM
fm_xtk fm_xtk is offline
Does anyone know the power rewuirements of Accel cards? I have bought a second hand Magma EB7 and loaded it fully with 7 cards. I am getting occasional Kernel Panics and am trying to figure out what the problem may be.
Whilst the chassis itself works great and all cards pass Digitest it was built in 2008 so the PSU could well be starting to give up slowly.
2x Hackintosh X79
HD7 Accel PCIe, Magma EB7 chassis
PT 10.3.10 Mac OS 10.9.5
SSL Delta Link HD 160 I/O
COCKOS REAPER (latest)
RME MADIFX (192 I/O)
ProControl (32 channel)
Old 12-09-2014, 08:09 AM
Raoul23 Raoul23 is offline
When I got my HD rig I had issues with the USB sockets sharing IRQ's with the PCI slots so I had to turn some off in the BIOS, now everything works great is this what your seeing?
Raoul Crane
www.blaze-studios.co.uk
PT 10.3.10 HD Accel 6, Mac Pro 5.1 12 Core 3.46hz Dual Boot Lion 10.7.5 and Maverick 10.9.5 32GB Ram Magma PE6R4i Chassis
  #16
Old 12-09-2014, 02:59 PM
Hi Raoul, thanks for your reply. Unfortunately I don't know what any of that means... I am using a MacPro (1,1) so have no access to a BIOS. It could be an issue to do with power on the PCIe bus though. I am still trying to figure it out.
I thought it might have been bad RAM but I don't think that is it. Will have to investigate further.
2x Hackintosh X79
  #17
Old 06-10-2015, 10:52 AM
fizpop fizpop is offline
I am having the same problem. Except im not using an external chassis. I have a Mac Pro 4.1 that had an HD3 system in it and it worked perfectly. We just upgraded the 4.1 to HDX and today put the HD3 system in a Mac Pro 3.1.
The 3 HD cards are mounted in the Mac Pro (As apposed to a chassis)
The 3.1 gets stuck on "Initializing Hardware (DSI)"
I tried it with 2 cards and still the same problem.
I then tried with just the core card and it works perfectly.
I recently put a Radeon HD5770 in the 3.1 from a 4.1 and it works fine but I thought it might be drawing to much power for all the cards to work, so I put an old GT120 in and still the same problem. So im not sure if its a power thing.
I will try it in a 4.1 tomorrow and see if I have any luck. In the mean time, anybody have any ideas of what I can do?
Oh and I have also trashed all the prefs multiple times and re-installed Pro Tools as well and still no luck.
__________________________________________________
Mac Pro 3.1, Dual Quad, 16GB RAM, Radeon HD5770
HD3 Accel PCIe
Pro Tools 10.3.9 Mac OSX 10.8.5
Digi 96 IO
Digi Sync IO
Lynx Aurora 8 with LT-HD
  #18
Old 12-06-2019, 09:06 PM
Andro Andro is offline
Hi guys!
And now this happened to me. MacPro 3.1. Maveriks. No chases just 2 cards in MacPro. Any thoughts? Thank you!
Ultimatum
art production
Mixing & mastering, drums, instruments, vocal editing on-line, re-amping
Pro Tools HD, TL Audio Tube Console, Empirical Labs EL8X Distressor,
Revoice Pro, Melodyne
PT HD8 - Stuck at Initializing Hardware (DSI) RoofTopLuki Pro Tools TDM Systems (Mac) 5 07-07-2014 11:03 PM
pro tools 10 HD stuck at Initializing Hardware (DSI) blujway macOS 3 05-15-2012 04:28 AM
Pro Tools 10 not opening stuck on initializing machine control!! wullie macOS 4 11-20-2011 08:39 PM
I can't open Protools 8; stuck on Initializing Machine Control ashtyn.eb 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 12-25-2009 03:07 PM
Pro Tools 8 LE not opening stuck on initializing machine control!! digartisan 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 8 11-29-2009 04:33 PM
