Pro Tools 8 LE not opening stuck on initializing machine control!!
Ok so i first tried to upgrade from 7.4.2 LE, I launched protools 8 and it freezes at Initializing machine control.
Trashed Prefs using Protools Pref and Database Helper app Launch again, same problem. Removed all third party Plug-ins rebooted Launch again same problem. Uninstalled Protools 8 completely, removed all third Party PLugins, Ran App Zapper over the Digidesign Folder to be sure. Rebooted RE-installed protools 8, Launched Protools 8 LE... hangs on Initializing machine control. Watching it spin for 30 min. MaCBook Pro 2.53 4 GIG RAM 300 GIG 7200 RPM MAC OS 10.5.5 MBOX2 MICRO |
Re: PRotools 8 LE not opening stuck on initializing machine control!!
Model: MacBookPro5,1, BootROM MBP51.0073.B02, 2 processors, Intel Core 2 Duo, 2.53 GHz, 4 GB
Graphics: kHW_NVidiaGeForce9600MGTItem, NVIDIA GeForce 9600M GT, spdisplays_pcie_device, 512 MB Graphics: kHW_NVidiaGeForce9400MItem, NVIDIA GeForce 9400M, sppci_pci_device, 256 MB Memory Module: BANK 0/DIMM0, 2 GB, DDR3, 1067 MHz Memory Module: BANK 0/DIMM1, 2 GB, DDR3, 1067 MHz AirPort: spairport_wireless_card_type_airport_extreme (0x14E4, 0x8D), Broadcom BCM43xx 1.0 (5.10.38.9) Bluetooth: Version 2.1.2f8, 2 service, 0 devices, 1 incoming serial ports Network Service: AirPort, AirPort, en1 Serial ATA Device: ST9320421AS, 298.09 GB Serial ATA Device: HL-DT-ST DVDRW GS21N USB Device: hub_device, (null) mA USB Device: Mbox 2, (null) mA USB Device: Built-in iSight, (null) mA USB Device: Keyboard Hub, (null) mA USB Device: USB-PS/2 Optical Mouse, (null) mA USB Device: Apple Keyboard, (null) mA USB Device: BCM2045B2, (null) mA USB Device: Bluetooth USB Host Controller, (null) mA USB Device: Apple Internal Keyboard / Trackpad, (null) mA USB Device: IR Receiver, (null) mA |
finally got it to work after i unplugged my Logitech USB hub, Protools then worked fine. Weird.
I'm getting the same thing as well.
I recently purchased a MacBook Pro 15" laptop and it has Snow Leopard. I also purchased an MBox2 Bundle a few months ago that had PTLE 7.4. I installed PTLE7.4 and then immediately did the upgrade to PTLE 8.0. When launching PTLE 8.0, I get a bunch of error code 5000's indicating that it can not load the default plug in's and I just "OK" past them. Finally, I get to the PT splashscreen indicating that it is trying to Initialize Machine Control. It's just locked up sitting there. Any thoughts?? |
Check your Applications/Digidesign/Pro Tools folder for the Machine Control file, and delete it if it is there.
Administrator Avid Pro Audio Community |
I checked my Applications/Digidesigns/ProTools folder for the existence of a machine control file and I do not see one..
I also ran SpotLight to see if it found anything that started with machine and there was not anything associated with DigiDesign or ProTools.. I have a new MacBook Pro that came with Snow Leopard.. I first used my installation DVD for PTLE 7.4 and then immediately executed the upgrade file for PTLE 8.0, if this has anything to do with what I am experiencing.. Since I have Snow Leopard as my OS, do I need to start from scratch with a clean installation of LE 8.0.3pr?? Is that possible (I believe the updates are if you already have LE installed)?? |
Re: Pro Tools 8 LE not opening stuck on initializing machine control!!
I'm having the same problem. Brand new Macbook Pro running Snow Leopard went through the PT 8.0 install without a problem, but is now not letting me go beyond "Setting Up Peripherals Initializing Machine Control". I'm in the process of downloading 8.0.3pr after uninstalling and reinstalling 8.0 with no success. Should I at least be able to start it prior to 8.0.3pr being downloaded??
Actually, cancel that. 8.0.3pr was what I needed to get the whole thing up and running, but now it's as smooth as anything.
Pro Tools 10 not opening stuck on initializing machine control!! | wullie | macOS | 4 | 11-20-2011 08:39 PM |
I can't open Protools 8; stuck on Initializing Machine Control | ashtyn.eb | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 12-25-2009 03:07 PM |
Pro ToolsLE 8 stops loading at '' initializing machine control'' | Stamak | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 07-09-2009 05:40 PM |
PTLE8 can't startup on "initializing machine control | King Kong | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 05-26-2009 04:06 PM |
PT LE 8 new simptom - hangs on initializing machine control | music project | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 12-23-2008 11:41 AM |
