Old 04-16-2005, 01:00 PM
jeremyroberts jeremyroberts is offline
Default 6.9 TDM plugin updates?
Am I missing something? I can't find the 6.9 plug updaters. The 3rd party plugs distributed by Digi, and the "purcahsed" plugs from Digi all have their own version numbers (and update links) - but the "bundled" plugs, such as the audiosuite plugs and other bundled "6.7" version plugs -- can someone point me to a link for these or if there is no update, tell me that 6.7 is Ok to use with 6.9?
Thx
jr
--Jeremy
Old 04-16-2005, 03:50 PM
Avid's Avatar
Avid Avid is offline
Administrator
Default Re: 6.9 TDM plugin updates?
Hi Jeremy,
The 6.9 Web Updater will install all of the current DigiRack plug-ins, now including EQ III.
I'm still checking into whether there are any non-core plug-ins that were specifically updated for 6.9, and I haven't found any so far. The links on the 6.9 optional software page:
http://www.digidesign.com/download/69/sw.cfm
are mostly going to the individual product pages here:
http://www.digidesign.com/developers/plugin_info/
When you click on the Download sections for each plug-in, it will give the version number. Like I said, I have not found any yet that I am aware of that were specifically revised for 6.9, but I will be checking more on Monday.
So I believe as long as your plug-ins (and your PACE drivers) are up to date, you shouldn't run into problems on 6.9 with any plug-ins you were using in 6.7.
Please let me know if your experience is any different than that, and like I said, I will be checking with folks regarding all of the Digi and 3rd party plug-ins with 6.9.
Administrator
Old 04-16-2005, 04:28 PM
Steve MacMillan Steve MacMillan is offline
Except, when you list the plug-ins in the plug-in selection menu by manufacturer, then sometimes you get several folders for the same company with slightly different syntax.
My Digicore plug-ins stayed 6.7, only the mixers changed. Everything seems to be working just fine.
STeve
macmandigital.com
Old 04-16-2005, 04:37 PM
cmaynes's Avatar
cmaynes cmaynes is offline
The 3rd party plugins need to be updated- Some that are not correct are McDSP, Sony and Bonb Factory.
Send messages to the various vendors so hey can be made more aware of the issue,]]
charles maynes
charles maynes
sound design and recording for film and media
818 618 0580
Member IATSE Local 700, MPSE, ATAS, NRA & USMCHC.
Old 04-16-2005, 04:52 PM
mixer mixer is offline
no midi controllers show up in 6.9.
www.garyvandy.com
Old 04-16-2005, 05:42 PM
DigiTechSupt's Avatar
From the download area:
Legacy MIDI Controllers
The following control surfaces were not tested with Pro Tools LE 6.9, and therefore are not officially supported:
JL Cooper CS-10™ MIDI series
JL Cooper MCS 3000 series MCS-Panner™
Peavy PC-1600™
The Pro Tools LE 6.9 installers do not install these by default. If you have a MIDI control surface that uses one of these control surface personality files, you will need to install separately:
http://www.digidesign.com/download/controllers/
Best regards,
Digidesign Technical Support
Avid Audio Tech Support
Support FAQ
Old 04-16-2005, 07:51 PM
Dutchmuzik Dutchmuzik is offline
I really like the new Category and Manufacturer list for the plug-in folders but some are showing up in the wrong folders. McDSP, SoundToys, Sony has 2 folders. I would also like to see a BombFactory folder.
Old 04-17-2005, 05:32 AM
Drew Mazurek's Avatar
might be related.....
what are the mixer plugins that end in _b. i've got an extra set of mixer plugs that i didn't notice before.
www.drewmazurek.com
Old 04-17-2005, 06:42 AM
frenchman frenchman is offline
I would be really grateful for Digidesign and plugins makers to team up and publish on the web a compatibility table for all current plugin versions and Pro Tools software versions.
Hunting down plugin version is becoming a very time consuming process and I am certain that this could be solved with some clever thinking...
Practically this could take the form of a dynamic web page where all plugin makers could contribute directly current version details and links to the download section where the update can be found. In that way Digidesign would have little additional work to do.
Mark Haliday
France, Rochefort 17300
Mixing & Mastering, Writer, Teacher
Pro Tools Ultimate & Carbon
M2 Max Studio
Old 04-17-2005, 08:36 AM
whtrabit whtrabit is offline
I agree with you Frenchman.
As far as the plugin arranging why can't we create our own folders so that the plugins end up in the correct folder--its amazing that some of these Digi partners' plugins end up in the wrong folders. Pluggo is one set that should have its own folder due to the number of plugins--I am still on 6.4 so I have not experienced this first hand--just reading the posts on 6.9.
jimmy
15" Macbook Pro R 2.6 i7 Quad/16GB RAM/OS X 10.10.5
27" iMac 2.8 i7 Quad/16GB RAM/OS X 10.10.5
Studio One 3/Reason 8/Live 9/Logic Pro 9/Main Stage 3
Plugin Updates bcs723 VENUE Live Sound Systems 3 10-19-2008 07:36 PM
Plugin updates for 6.7 Fader Invader Pro Tools TDM Systems (Mac) 1 12-08-2004 05:50 PM
6.4 plugin updates FDurrett Pro Tools TDM Systems (Mac) 2 08-02-2004 10:33 PM
HD Plugin updates DLS Pro Tools TDM Systems (Win) 0 07-16-2002 01:43 PM
plugin updates for the web download AmericanCheese Pro Tools TDM Systems (Mac) 0 03-05-2001 05:40 PM
