#41
Re: no DSP plugins in PT HD 12.5.1
Great progress, but...
Wait, so you never actually properly uninstalled the HD Driver??? That was the main suspect from the get-go! The HD uninstaller should be in the HD driver .dmg that you download from your Avid Account, has been in the past, I don't have a recent driver .dmg with me. I would try to do the proper uninstall, all the stuff I mentioned before, if not then presumably you can clone the disk that works. I had also asked a favor of support could contact you so that may happen. If you already have a case open post the number here. |
#42
There's no HD uninstaller inside the HD driver. Only the installer.
I agree with you but there's no way to properly uninstall the HD driver. See attached pix. Thanks for the help with tech support. I had a case number but avid closed this morning as I don't have a support plan. Your case number 03700821: PT HD with HDX running as Native only is now closed. Quote:
#43
""Update"
I was able to fix the problem by going inside all avid and deleting what I think was the audio driver and also trashing pro tools and re-installing it. DSP is now working and that weird page in the playback engine is now gone. Thank you all for your help and suggestions. Louis |
Copy/paste plugins settings doesn't work on certain plugins | yazoo | Post - Surround - Video | 0 | 08-04-2014 04:46 PM |
FS : Plugins alliance, avid, flux, waves plugins, blastwave sound library | Roll | Buy & Sell | 5 | 03-11-2013 06:20 AM |
Lateny Issue with PT8, 2009 mac Pro (OSX) and NI Plugins/Spectrasonic Plugins | djtorch | Pro Tools M-Powered (Mac) | 1 | 01-14-2010 12:11 PM |
Plugins missing in drop down list, but in plugins folder ?? | mixingmadness | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 4 | 09-12-2007 10:27 AM |
PLUGINS problem - paid for factory plugins, DON"T WORK!! | rhinostylee | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 5 | 07-28-2007 10:59 AM |
