  #31
Old 03-22-2019, 09:23 AM
Peter - IK Multimedia's Avatar
Peter - IK Multimedia Peter - IK Multimedia is offline
IK Multimedia
Default Re: Announcing SampleTank 4
Please note that SampleTank 4.0.3 is now available in your IK User Area!
What’s New
Changes from version 4.0.2:
• Improved memory and processor usage.
• Added a Streaming tab in Settings.
• Fixed an issue with crashes on FL Studio macOS.
• Fixed an issue with infrequent crashes on VST, AAX, and Standalone.
• Fixed an issue with possible missing font on Windows.
• Fixed an issue with authorization.
• Fixed an issue with recognizing the current ST3 path at first launch.
• Fixed graphic artifacts while resizing window within a host.
• Fixed an issue with automation defaults within a host.
• Fixed Strummer steps sync within a host at first load.
• Fixed an issue with instrument saving due to unsupported characters.
• Added a brief install guide post installation.
• Improved the search responsiveness in the Phraser.
• Fixed an issue with loading ST3 Multis that include imported legacy instruments.
• Improved visual feedback for database rescan.
• A Sound Library Update 1.3 is available. This fixes various typos, macro errors and Multi and sample issues and includes additional Multis. Please download and install the Sound Library Update 1.3 available in your SampleTank 4 Sound Downloads dropdown menu.
• General reliability improvements.
Sound Library Updates
SampleTank 4 MAX Sound Library Update (1.3)
SampleTank 4 Sound Library Update (1.3)
SampleTank 4 SE Sound Library Update (1.3)
Instruments Installers (only necessary for new installs)
SampleTank 4 MAX Instruments Installer (1.1)
SampleTank 4 Instruments Installer (1.1)
SampleTank 4 SE Instruments Installer (1.1)
Samples Installers
These fixes installer compatibility with macOS 10.10 (Yosemite) and multi-parts are now interchangeable between versions have consecutive numbering.
UA Sounds Download UI improvement
Multiple file download functionality has been added to the User Area Sounds Download UI.
You can now can select multiple files from a list and download at once.
IK Multimedia - http://www.ikmultimedia.com
  #32
Old 04-11-2019, 11:09 AM
IK Multimedia
SampleTank 4.0.4 is now available in your IK User Area
Changes from version 4.0.3:
  • Optimized RAM / Virtual Memory Usage.
  • Fixed several crash issues on Studio One.
  • Fixed a crash when playing notes after loading several large sized Instruments.
  • Fixed a UI issue in FL Studio Mac when removing SampleTank 4 from a project.
  • Fixed a crash when loading instruments with corrupt sample (.pak) files.
  • Fixed Multis (combis from SampleTank 2 imported via SampleTank 3) not loading Instruments.
  • Fixed SampleTank 3 Instruments with Stretch Engine which caused glitchy audio on upper note ranges.
  • Fixed SampleTank 3 Edit Panel not applying PSTS/Stretch engine on all selected zones.
  • Fixed London Grooves Instruments crash.
  • Fixed corrupted Instruments switching between Resample and Resynth engine.
  • Fixed a sporadic crash when playing Arpeggios.
  • Fixed an issue with onscreen Pitch Bend not matching set values on Edit Panel.
  • Fixed concurrent Preanalysis tasks resulting in parts muting.
  • Fixed significant volume difference in SampleTank 3 and SampleTank 4 Instruments Accordion LH Mellow and Accordion Musette.
  • Fixed a feedback loop caused by Compressor.
  • Fixed trigger behaviour playing with Strummer .
  • Added scrollbar to Mod Matrix.
  • Added scrollbar to Mixer page.
  • Added Instrument size in the Browser INFO panel.
  • Updated Authorization Manager version 1.0.24.
  #33
Old 04-15-2019, 03:17 AM
simon.a.billington simon.a.billington is offline
Nice one. Thanks man.
  #34
Old 04-22-2019, 09:17 AM
IK Multimedia
No problem! I also have seen this new video from Simeon of Praisetracks.com that is quite nice:
https://www.youtube.com/watch?v=uf_H2XXV_T8
[IMG] code is Off
Announcing Fender Collection 2 for AmpliTube Peter - IK Multimedia AAX Plug-ins 35 01-16-2017 08:29 AM
Announcing the Tempo 1.0 widget Jory General Discussion 2 10-03-2006 08:16 AM
Announcing Mbox Avid General 0 01-17-2002 03:37 AM
Announcing Pro Tools|HD Avid General 0 01-17-2002 03:33 AM
