Re: Pro Tools 12.x performance with MBPr
Your idol is 30-40% when you have pro tools and or a session open and not playing?
If so, what now? hahahah Take it in to apple? Also, what version of Pro Tools and OSX are you using? On another note, I also looked at activity monitor, and pro tools was showing approximately 140 for CPU%. Does that seem normal? I also just installed pro tools 12.5.2 a few minutes ago, and oddly, I think the system usage in pro tools went down a good 10%. It seems less sporadic which is good. However, the fans still come on and keep going at a noticeable level. I even opened an older session that was smaller that never had this problem, and it's happening with this older session now too. Last edited by Thenewexhibit; 07-11-2016 at 12:44 AM. Reason: Adding more details. |
yes that's correct,i have a session open right now but not playing, full of aax instr and fx, and audio tracks as well. 40 degrees. I have istat permanently in my menu bar (istat menus it's called) which is a great little cheap app that shows real time cpu usage and temps, also shows cpu usage of each thread individually. What is your temps when pro tools is CLOSED and just browsing web? Right now I have 10 tabs open in safari, I have vlc open in the background playing white noise to sooth my tinnitus, and the temp is 29 degrees celsius.
- Intel 14900K/NzXt Kraken Elite/64GB Kingston DDR5 6000 mhz (32x2)/ Asus Pro Art Z790/Asus 4090/Win 11 Pro 23H2/UAD Apollo 8 x2 w TBolt 3 card u/g/UAD Twin X. |
How high does your fan get when you're playing back that session? Also, what OSX and version of pro tools are you using? Thanks for taking the time to tell me about all of this. I do appreciate it! |
Sounds like hardware problems then. |
PT 12.5.2 vanilla. I have a uad thunderbolt apollo twin duo i use with the macbook. I also have an apollo 8 in the studio for the imac. When i am working in the studio room, i attach the apollo twin to the 8 to give me two extra dsp and a big knob monitoring controller, and then i run the macbook just off of the internal sound (which is actually very very good, the best around as far as notebook integrated sound goes). I have it running into a powered monitor (ik iloud) on my laptop desk. Sometimes i do compose there too, just depends on the mood. Sometimes i take it to bed with me and write there. NOTE, i *do* have it on a coolermaster laptop stand, so it's elevated and has good airflow, so that might make a difference too.
#16
Also, as far as the cooler goes, what model do you have, and are the cooler fans loud? |
#17
coolermaster ergo stand III.. it is always on that.. the fan is not audible unless you put your ear just about touching it, but it's not really going to cool the macbook much. This is because, the mac exhausts from the rear.. its only really to have an integrated 4 usb hub, all the different angles, and the cable management. It's a wonderful product.
#18
That being said, he cleaned out the dust from the fans too. It now runs quiter, but, unfortunately the problems still persist. Fans come on on any session, and this never happened before. Although the fans are quiter, it still gets very hot and is noticeable; around 95 degrees cecius when playing session in pro tools, and around 80 in idle. It's also still around 56 degrees ceclcius after startup and there is nothing going on on my computer. It's strange that we have the same machine, yet the temps are 30-60 degrees off at times. Thanks for getting back to me about all of this. What would you guys do? I mean, at this point for now, realistically, the only thing I can do is continue to work, but it concerns me about the computer not performing like other's computers do. Last edited by Thenewexhibit; 07-11-2016 at 07:26 PM. Reason: Typo |
#19
Fans come on and it never happened before.... I would suspect a finger or software problem well before a hardware one.
I don't think there was an answer to what was asked by somebody earlier about the GPU. Are you running discrete GPU only or is automatic switching enabled? Whatever you have set try the opposite. You can try a full clean install of OS X (ideally not El Crapitan) and just see if that happens again. Do that install onto a spare disk partition or a separate external drive. Start with just web browsing (with no plugins/extensions) before installing ILM, Pro Tools. And then see how that works before installing any third party plugins. I'm suspicious of bad things from lots of the crapware like Pro Tools collaboration, Avid app manager, Pro Tools First, etc. uninstall all that crap. Ditto for other bloatware like Adobe CC and Microsoft Office 365. Keep all that crap off your DAW system if you can, or if you can't then it's up to you to test before and after with each one. |
#20
Pretty sure you've got thermal issues in your MacBook Pro.
I had the same kind of problems on my laptop (Retina i7 MBpr 2013 16GB RAM 512 GB Flash SSD) and when it was checked by Apple, they ended up replacing the motherboard. "Thermal issues" was the buzzphrase from the repair folks. This was showing up in PT10HD with a session of say 4 tracks of audio. Fans would ramp up If there was a video track the fans would kick in until lift-off nearly occurred. Get it seen to. Last edited by Ray JB; 07-11-2016 at 08:12 PM. Reason: typo |
Fan speed on mid 2014 MBPr 15" | Thenewexhibit | Pro Tools 12 | 2 | 01-13-2016 08:18 PM |
NEW MBPR Purchase | kyluigi | macOS | 32 | 09-24-2014 12:45 PM |
PT11 on MBPr w/o 2nd HD - experiences? | BCnSTL | macOS | 1 | 06-26-2014 03:32 PM |
PT 11 + Mbox on 13" MBPr | njuk-njuk | macOS | 8 | 07-05-2013 08:21 PM |
Eucon 2.6.2 kills my MBPr | soratach | Artist Series | 1 | 08-09-2012 01:12 PM |
