  #221
Old 10-25-2015, 07:43 AM
Jay_uk Jay_uk is offline
Default Re: Eleven Rack Presets Thread
some free vidz available from PTE…..getting some signature tones with eleven rack
http://www.pro-tools-expert.com/home...ed0ub0txjdwy91
  #222
Old 03-30-2016, 07:31 AM
Noiselab Noiselab is offline
I'm in a bit of a spot, and I'm hoping someone can help me out. Before the expansion pack release, I had a client use a couple of mildly tweaked factory rigs (one was called "Sinus Infection") that really worked well in the context. Well, the client is back and wanting to use those rigs again.
I could have sworn that I exported/saved the pre-expansion rigs before loading the expansion pack, but I can't find them in my archives. I even went back to the archives of the old projects to see if the rig was saved with the project. No luck! What was I thinking?!
Might somebody here have an unmolested copy of the original factory rigs?
Many thanks in advance!
As a side note, it's probably a good idea to export your rigs and save them with your session files so you don't find yourself in my current position...
NL
  #223
Old 03-30-2016, 07:53 AM
OK, I found the "MM Sinus Infect" rig in the Sweetwater set, but I've yet to find the other half-dozen original factory rigs for this client.
Any help (private e-mail of an xml file...?) would be greatly appreciated.
P.S., Another good tip to save your future sanity is to also put the name of the rig in the comments of track where it was used. If you're tweaking the same rig between tracks, make sure you save your tweaked rig (named appropriately of course) with your session backup as a "safety". I'm now wanting to travel back in time and strangle my past self... I guess I need to hire and train a good assistant engineer - because clearly, I'm an idiot that can't be trusted with theses tasks!
NL
  #224
Old 03-30-2016, 08:47 AM
Benoni's Avatar
Benoni Benoni is offline
P.S., Another good tip to save your future sanity is to also put the name of the rig in the track where it was used. If you're tweaking the same rig between tracks, make sure you save your tweaked rig (named appropriately of course) with your session backup as a "safety". I'm now wanting to travel back in time and strangle my past self... I guess I need to hire and train a good assistant engineer - because clearly, I'm an idiot that can't be trusted with theses tasks!
NL
I thought I had these on my Eleven Rack blog, which I do, but they are included with the All Benoni Studio Rigs.
I do have them, Original Eleven Rack Factory Rigs linked here.
I'll write up a blog post to make them easier to find.
Brian
Windows 11 Pro | macOS 12
Pro Tools 2022
benonistudio.com
Youtube Channel - benonistudio
Plugin Deals
@benonistudio
  #225
Old 03-30-2016, 09:02 AM
Awwwww, dude! You are a life saver!
Many thanks!!!
NL
  #226
Old 01-17-2018, 09:49 PM
polar_ninja polar_ninja is offline
I’m searching for that specific Santana sound. Has anybody a preset that sounds like it?
Thx
Ricardo
Verzonden vanaf mijn iPhone met Tapatalk
Eleven rack adding new presets error ! emmany Eleven Rack 2 08-23-2019 11:19 AM
Check out the Eleven Rack Presets Matched for Eleven plugins by Pro Tools Expert! Justin1524 Eleven Rack 0 11-27-2015 02:53 PM
Loading eleven rack presets into your box YYR123 Eleven Rack 0 12-16-2013 10:49 AM
Eleven plugin (not Rack) save presets? Teolin Virtual Instruments 0 07-20-2013 11:01 AM
Eleven Rack Presets Unavailable joedexter23 Eleven Rack 4 07-19-2011 05:07 AM
