Old 01-20-2020, 05:59 AM
chris.d chris.d is offline
Default Ultimate is the only way to have 32+ IN/OUTs?
Simple (desperate) Question
Is the only way to get more than 32 tracks of I/O from PT to upgrade to PT ultimate?
Old 01-20-2020, 06:15 AM
pm mastering studio's Avatar
pm mastering studio pm mastering studio is offline
Default Re: Ultimate is the only way to have 32+ IN/OUTs?
indeed you'll have to Go the HD(x) ProTools Ultimate way which means you'll have to have the Avid Hardware (to my knowledge that is)
with kind regards
Philippe Meiresonne
(Belgium)
http://www.pm-mastering-studio.com
SYSTEM 1 : Main recording - HDX MAC Pro 2023 M2 Ultra Running Sonoma 14.4
ProTools Ultimate 2024.3| 1xHDX Card | Mac Pro M2 Ultra 128Ram 2TB|3x PRE | 2x Avid 96 |1x Avid 192 I/O 16/16 Analogue | 1x Acid HD I/0 16/16 Analgue
Midi I/O | D-Command ES +16 fader Pack | Xmon | Eleven Rack + Dolby Atmos 7.1.4 Surround Adam S3H speaker System
System 2 : Project System - ProTools CARBON Running Sonoma 14.4
MacStudio M2 Ultra |64 GB RAM | ProTools 2024.3 Ultimate/Studio | SSL2+ | AVID S1+DOCK + ProTools|Carbon + ProTools|Carbon PRE
Old 01-20-2020, 06:18 AM
are you sure the hardware is needed too? (even worse than i thought?!?)
Old 01-20-2020, 06:29 AM
according to the avid website that is. (https://www.avid.com/pro-tools/comparison than Key Features\ Maximum inputs (hardware dependent) \ click on "more information")
Other hardware uses ASIO driver and asio is limited to 32 i/O's
I do think there's a way to go the DANTE way but I'm not skilled in that (only using HDx here) to know if this exceeds the 32 limitation. I suspect you will be able to route more than 32 in/outs but only 32 In/outs at the same time for recording/playback)
Philippe Meiresonne
(Belgium)
Old 01-20-2020, 06:58 AM
thank you for your knowledge!
Old 01-20-2020, 07:45 AM
JFreak's Avatar
JFreak JFreak is offline
Yes -- HDN for 64 i/o and HDX for unlimited (hardware dependent that is).
Dante goes to PT via MTRX interface.
Janne
Old 01-20-2020, 07:49 AM
HurtMesaMusic's Avatar
HurtMesaMusic HurtMesaMusic is offline
I have two Apollo x8ps and an Asp 800. With PT Ultimate I have 32 I/O on a Mac Mini.
Old 01-20-2020, 07:54 AM
JFreak's Avatar
In case someone new is wondering, PT will only see first 32 i/o presented by your ASIO driver. PT has no way of re-arranging which i/o they are, that needs to be set up outside of PT.
Janne
Old 01-20-2020, 09:23 AM
uptheoctave uptheoctave is offline
You can also go Dante via several options from Focusrite- Red interfaces give you 64 channels with HDX.
James Richmond
https://www.jamesrichmond.com
2019 Mac Pro, 2022 Mac Studio Ultra
Avid S6, HDX2, MTRX II, MTRX, DAD AX64, AX32, Focusrite Rednet PCIER, Trinnov MC8 Pro.
Studio: https://www.voltperoctave.com | Music: https://www.euclideancircuits.com
Latest Article: Auto-Bounce for Logic Pro
Affiliate Links:
Auto-Bounce by Tom Salta
Dreamhost Web Hosting
Old 01-20-2020, 02:45 PM
soundasleep's Avatar
soundasleep soundasleep is offline
In short - yes. You have to have PT Ultimate, but it ALSO has to "see" a digilink interface, via HDX or HD Native. Dante alone only gets you 32. BTW, You only get 32x32 with Red4 to RED8 pre boxes - even though they have digilink ports for 64.
32x32 with any interface, but 64x64 (or up to 192x192) with enough digilink interfaces connected, using the HDNative or HDX playback engines.
Reverb is a lie.
[email protected]
Bought PT Ultimate reinstatement, can't activate Ultimate subbasshead Licensing & Accounts 3 11-29-2019 09:23 PM
Digi002 rack main outs vs monitor outs studiojb 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 11-03-2012 07:46 AM
Problem with 002 main outs as well as head phone outs? wiseal1 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 12-10-2009 11:36 AM
Vista Ultimate 64 (the ultimate dissapointment) Filmusic 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 5 08-03-2009 04:44 AM
Digi Outs work fine---Logic not getting signal to outs Thou 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 08-29-2001 02:52 PM
