front panel gain
what are the line inputs on this digi 001 set to? +4? are the front line inputs independant of the gain knobs? line inputs don't have gain settings right? at least pro line inputs.. am i wrong?
Re: front panel gain
those knobs are for the mic pre gains i believe....
DIGI002R, PTLE8.0.5, Windows XP, Asus K8V SE Deluxe, AMD64 3000+ 1.5GB ram, ATI Radeon HD3xxx AGP, dual 19 inch LCD screens |
The front TRS inputs are affected by the gain controls. Use the pad switch if you're plugging in something at line level.
The rear inputs do have some adjustment from within PTLE. Under the Setup menu choose hardware, and then there's a button with "other" or something like that on it. (Sorry, I'm not at my PT machine.) In there you can adjust the rear inputs gain, change you optical digital in/out between 2ch & 8ch (I think) and you can also enable or disable a high pass filter for ins 1 & 2. Someone correct me if I'm speaking crap!! Hope this helps. Mark
http://www.oneearthproductions.net |
How do I select the mic input on the front panel...got it! | Sam C | Eleven Rack | 0 | 01-17-2012 02:13 PM |
Front Panel DI on 003+ not working. | azuraman | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 4 | 07-13-2009 03:29 PM |
Firewire led on front panel is red!!!! | SMO500 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 5 | 06-29-2006 01:22 AM |
OT, different colored front panel for 001 ???? | Bob Legs | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 15 | 07-19-2003 12:33 AM |
Unity gain on 001 front panel inputs | Percustard | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 3 | 10-29-2001 10:53 PM |
