Old 11-01-2015, 07:07 PM
Rob2Smith Rob2Smith is offline
Default Using Print Track Audio Files
You guys helped me get my bearings again in PT with routing out board, managing busses and printing. Thank you very much!
Now, when I print my mix - when I look at the waveform, it shows to be a single stereo file. However, if I go to the folder in finder, it is an individual L and R file. How do I fix this so that it prints stereo interleavened. I don't believe I can make use of two mono files without additional processing of some sort.
Any guidance?
Thanks
Rob
Old 11-01-2015, 07:20 PM
zedhed's Avatar
zedhed zedhed is online now
Default Re: Using Print Track Audio Files
Bounce it out of session, select interleaved in bounce options.
Import it back into session if you want though PT will treat it the same as L&R files if they reside in a stereo track.
Too much blood in my drugstream
Gigabyte X99 SOC Force Mobo Bios vF6d
Intel Core i7 5930k socket 2011 v3 @ 3.50GHz
32GB DDR4 Crucial RAM
System: Samsung M.2NVME SSD 960 Evo
Record: Samsung M.2NVME SSD 960 Evo
Samples: Samsung SATAlll SSD 840 Pro
Storage: 2x Samsung SATAlll SSD 840 Pro
EVGA GeForce GTX 750 Graphics
PT 11HD (v11.2.1) Omni s/pdif w Eleven Rack
HD 96I/O
Win 8.1 Pro
Hi, yes - thanks. I am aware of bouncing but trying to use a print track.
Old 11-01-2015, 07:33 PM
zedhed's Avatar
Originally Posted by Rob2Smith View Post
Any guidance?
Thanks
Rob
What are you trying to achieve?
HD 96I/O
Win 8.1 Pro
Old 11-01-2015, 07:35 PM
I'm creating a master recording of the session, avoiding the bounce process (topic for another conversation) and want to have a stereo file to burn a CD or send to mastering. My only hiccup is that the print track is creating 2 mono files.
Old 11-01-2015, 07:42 PM
GeoffLee GeoffLee is offline
Export it as a stereo interleaved file. 'Export Clips as Files.' at the top of the clips list. Choose interleaved in the format options.
2010 iMac 4gig ram, OS 10.8.5, PT12.4, Saffire Pro 40, Octopre.
2011 Macbook Pro 4gig, OS 10.10.4, PT12.4, Fast Track
Old 11-01-2015, 07:53 PM
zedhed's Avatar
Ha Geoff beat me to it
HD 96I/O
Win 8.1 Pro
Old 11-01-2015, 07:59 PM
Thank you both!
Old 11-01-2015, 08:15 PM
Watagushu2013 Watagushu2013 is offline
In protools 10 and beyond in the session setup window there is a square box that you can click and enable stereo interleaved when recording.
Good luck.
Print audio from Midi Track (not Instrument Track) hardcase macOS 32 10-08-2015 05:51 AM
How to print each MIDI track to Audio? PT9 sylviesongs macOS 2 10-19-2011 03:07 PM
Recording a click track causes audio files to print early? doubtful guest Pro Tools TDM Systems (Mac) 2 03-29-2011 11:37 PM
How To "Print" Track? tikboy 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 4 05-30-2006 11:17 PM
How does one print Midi to an audio track? Dan M. MIDI 1 09-17-2004 08:20 AM
