Old 07-26-2015, 07:13 AM
paulvandyke999 paulvandyke999 is offline
Default Can Mix Rack take two MADI cards?
I'm getting mixed answers on this question. Can a MixRack for a D-show accept two MADI cards? I need to get about 90 channels into the D-show through MADI. Secondly, one person told me that I need to have two Stage rack cards installed in a mix rack or FOH rack in order to use two MADI cards. Is this true?
Old 07-26-2015, 07:20 AM
Brent Lind Brent Lind is offline
Default Re: Can Mix Rack take two MADI cards?
I can't speak for the mix rack, but in a stage rack you would need two Madi cards installed, which would give you 128 inputs.
Old 07-26-2015, 08:35 AM
Thanks Brent, I'm actually not planning to use a Stage rack at all. Just MixRack or FOH rack
Old 07-26-2015, 10:14 AM
My bad, I meant to say FOH rack. Obviously no stage rack needed:)
Old 07-28-2015, 01:51 PM
Ed Spoto Ed Spoto is offline
A Mixrack takes only 1 MADI card
Old 07-28-2015, 01:53 PM
From the manual:
Qualified VENUE Systems
Qualified VENUE systems include VENUE D-Show systems,
VENUE Profile systems, and VENUE Mix Rack systems.
On VENUE D-Show and VENUE Profile systems, up to two
MADI cards can be installed in a VENUE FOH Rack for a total
of 128 channels of digital I/O.
On VENUE Mix Rack systems, one MADI card can be installed
in a VENUE Mix Rack for a total of 64 channels of digital I/O.
Old 07-30-2015, 05:26 AM
Mike Z's Avatar
Mike Z Mike Z is offline
Mix Rack supports 2 MADI cards.
It should work out of the box unless it's an older Mix Rack in which case you may need to order a special ribbon cable called the "clock source jumper cable"
-Mike
Avid Live Sound Support
2 venue profile counsels and MADI cards Psideras VENUE Live Sound Systems 2 12-13-2013 08:41 AM
MADI/HDX Cards with SC48 rlower VENUE Live Sound Systems 0 11-17-2012 06:00 AM
AVID MADI - connect 2 MADI units? smc917 Pro Tools TDM Systems (Mac) 4 07-25-2011 02:38 PM
Venue & MADI - Sharing a Stage Rack and Word Clock... Chris Johnson VENUE Live Sound Systems 3 09-17-2010 03:28 AM
Will an SSL MADI system work with a 003 Rack? dru0013 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 05-16-2010 03:08 AM
