Old 02-06-2015, 05:08 AM
musicman691 musicman691 is online now
Default Re: 10.3.10 ran out of memory scanning plugins
Originally Posted by crizdee View Post
Ok i had to remove about 50% of my plugins from the folder before it would complete the scan and load, then add the plugins back in for a second boot.
other than that it all seems to be working ok.
Chris
You shouldn't have had to do that. Just restart PT10 and it will finish the scan. That's the way it's worked in before. Let it throw the error message and just restart PT10.
Jack
QAPLA!
Old 02-06-2015, 05:37 AM
Drew Mazurek's Avatar
Right. see post #2!!
www.drewmazurek.com
Old 02-06-2015, 05:53 AM
crizdee's Avatar
crizdee crizdee is offline
Tried restart and it did the same! might be because i have over 500 TDM/RTAS and over 400 AAX plugins.
removing about half the TDM/RTAS enabled it to finish a scan and open then i added the rest back in and re-booted and voila.
Maybe if i kept restarting it would have finally done it, but i didn't know it needed to do that! just though it was a problem and all i could think was to remove some plugins from the folder.
When did this issue start as I've never seen it before?
Chris
Producer, Engineer,
Slow Readers Club_Build A Tower top 20 UK album charts
www.ukmastering.com
PT10.3.10 Mountain Lion HD6 accel Magma PE6R4 Control 24 MacPro 12 Core 3.46ghz UAD-2 Octo x2. Manley Vari-Mu, Manley Massive Passive, SSL VHD, ADL600, Grove Tubes ViPre, Tube-Tech CL-1B. Hafler TRM active monitoring.
Old 02-06-2015, 07:15 AM
tonwurm's Avatar
tonwurm tonwurm is offline
Chris
it started with a high count of plugs in my plugins folder ;-)
occured since upgrading to PT10, at least with my system
Mac Pro 2010 - PT10 HD3, PT12 HD, Logic X, DP 7, VEPro, OSX 10.9.5 / 10.12.6
MacBook Pro - Logic X, Mainstage
Old 02-06-2015, 07:19 AM
dtmprod dtmprod is offline
Had a situation once where it would scan only so many plugins, then it would start all over again when I rebooted. What I ended up doing is removing all the RTAS plugins that were duplicating the AAX native ones. I guess you could go the opposite way, removing AAX native duplicating RTAS.
  #16
Old 02-06-2015, 08:08 AM
Eric Lambert's Avatar
Sometimes ya have to wonder if anyone reads these threads.
  #17
Old 02-06-2015, 08:09 AM
And #3.
  #18
Old 02-06-2015, 12:23 PM
Kristo Kotkas's Avatar
Kristo Kotkas Kristo Kotkas is offline
Had the same error, some demo licenses had run out and were automatically dismissed by my 10.3.9 install but now 10.3.10 woke them up I guess... Had to remove them to get PT to launch.
VENUE FAQ & download links, useful
AVID VENUE ILok driver download
VENUE Plugin DSP usage
My AVID:
  • Room A > HD4Accel PCI-CustoMac / 192D / PTHD10 / 2 x Artist Mix / Artist Control
  • Room B > HD3Accel PCI-CustoMac / 192D / PTHD10 / 2 x Artist Mix
  • Big Live > VENUE Profile 48/24 + 2nd Snake card, IOx, FWx, HDx, PQ Rack, 8 x PQ Controllers
  • Small Live > S3L-32 + Mac Mini - two systems - combined one 64/32 FOH / Mon setup
  • On stage > Pro Tools on laptop with variety of M-Audio boxes
  #19
Old 02-06-2015, 12:49 PM
Chris
For me I think it was PT10.3.8 or 9 this started.
Jack
QAPLA!
  #20
Old 02-06-2015, 01:11 PM
Bob Olhsson's Avatar
Bob Olhsson Bob Olhsson is offline
I started having that problem after I had AAX versions of most plug-ins. Removing the RTAS duplicates solved the problem. Last time I forgot to do that and didn't have the problem. One thing that's different is I'm running PT10 in windows 8.1 and I used to run 7.
Bob's room 615 562-4346
Georgetown Masters 615 254-3233
Interview
Artists are the gatekeepers of truth! - Paul Robeson
Pro Tools 10 HD runs out of memory when scanning plugins dj_grimmace Pro Tools HDX & HD Native Systems (Mac) 10 09-16-2015 05:11 AM
Plugins & Memory ~ BYPASS Zoduati 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 6 11-04-2012 07:31 AM
Live Lite 7 for Digi not re-scanning plugins Gothboy Virtual Instruments 0 09-21-2009 09:10 AM
"scanning program memory" freeze! viridis Digidesign Hardware & Software 2 09-07-2001 03:25 AM
Plugins and Memory Locations Scotty Tips & Tricks 4 08-28-2000 11:25 AM
