Old 02-05-2015, 07:19 AM
crizdee's Avatar
crizdee crizdee is offline
Default 10.3.10 ran out of memory scanning plugins
Just updated to 10.3.10 and getting this error message and PT won't boot now!
I haven't investigated it yet but has anyone seem this and know whats causing it? all my plugins are authorised and were working fine before the update.
Chris
Producer, Engineer,
Slow Readers Club_Build A Tower top 20 UK album charts
www.ukmastering.com
PT10.3.10 Mountain Lion HD6 accel Magma PE6R4 Control 24 MacPro 12 Core 3.46ghz UAD-2 Octo x2. Manley Vari-Mu, Manley Massive Passive, SSL VHD, ADL600, Grove Tubes ViPre, Tube-Tech CL-1B. Hafler TRM active monitoring.
Old 02-05-2015, 07:26 AM
Drew Mazurek's Avatar
Default Re: 10.3.10 ran out of memory scanning plugins
Just launch it again. It will pick back up where it left off.
10 has done for a while now. It's due to the extra scanning it has to do because of TDM, RTAS, and AAX plugins all being supported.
www.drewmazurek.com
Old 02-05-2015, 07:50 AM
Eric Lambert's Avatar
It's trying to create a map of your plugins and running into limits of RAM, so PT partitions the mapping into two or more scans, depending on how many plugins you have. The good thing is that it won't scan after it's created the map, not unless you delete the plugin file (I believe it's the ProTools.plist).
Old 02-05-2015, 11:18 AM
WernerF WernerF is offline
Anyone used it yet to see how it"s working? Not at the studio at the moment so i can't try it yet.
Old 02-05-2015, 11:28 AM
crizdee's Avatar
Ok i had to remove about 50% of my plugins from the folder before it would complete the scan and load, then add the plugins back in for a second boot.
other than that it all seems to be working ok.
Chris
Producer, Engineer,
www.ukmastering.com
Old 02-05-2015, 12:20 PM
Raoul23 Raoul23 is offline
Working good here so far. Haven't had time to give it a good work out though
Raoul Crane
www.blaze-studios.co.uk
PT 10.3.10 HD Accel 6, Mac Pro 3.1 Dual Boot Lion 10.7.5 and Maverick 10.9.5 32GB Ram Magma PE6R4i Chassis
Old 02-05-2015, 01:41 PM
That's all encouraging. Thanks for the info.
Old 02-05-2015, 01:56 PM
jeffro's Avatar
jeffro jeffro is offline
I did more than a dozen uninstalls/installs of 10.3.10, 10.3.9 and 10.3.8 on my HD rig in the past week and did not experience that error. If that occurs again for you or others we should get more info... plugin list, installed memory, etc.
Old 02-05-2015, 08:15 PM
Scan the thread a bit closer. It's not an error, it's an intentional function of PT. You may not have enough plugins to push PT past the RAM limits. We have a slew of computers running PT10 and only about 2/3 see this message.
Old 02-05-2015, 09:19 PM
jeffro's Avatar
Understood, was just sharing my experience.
My efforts were more ad-hoc, not part of the actual test effort for 10.3.10.
Still might be helpful though to get a plugin list from those of you seeing this.
Pro Tools 10 HD runs out of memory when scanning plugins dj_grimmace Pro Tools HDX & HD Native Systems (Mac) 10 09-16-2015 05:11 AM
Plugins & Memory ~ BYPASS Zoduati 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 6 11-04-2012 07:31 AM
Live Lite 7 for Digi not re-scanning plugins Gothboy Virtual Instruments 0 09-21-2009 09:10 AM
"scanning program memory" freeze! viridis Digidesign Hardware & Software 2 09-07-2001 03:25 AM
Plugins and Memory Locations Scotty Tips & Tricks 4 08-28-2000 11:25 AM
