#21
Re: Bios changes for improve
Flautista,
Just glancing though this, it appears to me that you are doing fine the way you are currently running.
#22
As i said the GA-X58A-UD3R has six slots i am using 3 slot with 3 match sticks each on is 8gb 1600 9-9-9-24 in slots 1-3-5 as manual said any comments are welcome, thanks.
Jascha Koneffke flutist www.prodmusica.cl GA-X58A-UD3R[/ I7 950 RAM 24Gb corsair 1600 (3 sticks) 9-9-9-24 MAC MacBookPro i7 2,3 15" RAM 16gb PT 11.3 003 Rack MBox 3 Pro |
#23
From one of the sites that discuss this RAM situation...
"In the early days of computing, RAM was small in capacity and very expensive. RAM is now one of the cheaper computer components, and with 64-bit processing, the amount of RAM that computers can use has become very large. For instance, 32-bit processors can address up to 4 GB of RAM, while 64-bit processors can address up to 16.8 million terabytes of RAM. While you’ll probably never reach a need for 16.8 million terabytes, a good rule of thumb is to have at least 2-3GB of RAM per processor core in your computer. Most current computers suitable for video editing support at least 8GB of RAM, and some support up to 64GB. We recommend you install as much as you can afford. Most computers require RAM to be loaded in matched sets (typically sets of two or four chips). Use great caution when purchasing additional RAM and follow the recommendations of your computer’s manufacturer for type and quantity. ECC RAM While RAM chips have become increasingly reliable, there is an additional advantage to have ECC (error correction code) RAM to avoid data corruption. This RAM design uses internal error correction algorithms to detect and recover from small errors. It is more expensive and slightly slower than non-ECC RAM. Note that Apple desktop computers support ECC RAM, as do most high-end PC desktops. Apple laptop computers currently do not support ECC RAM, but some PC laptops do."
Felipe Gonzalez A. Avid ACSR Elite Dante Certified http://felipousismix.wix.com/felipousismix Open Core Mac Pro OSX Ventura | ProTools HD 2023.x | Merging HAPI ADA8 | UAD Quad PCIe | Kali IN-8 | Presonus Temblor 10 | Softube, SSL, Universal Audio, Slate Digital, McDSP, Fabfilter, Plugin Alliance among other plugins |
#24
Just last time I checked gigabyte's site 6x4gb was the max. If I needed more than the 12gb (6x2gb) I now have, I would investigate more. But it seems to work for you. So good job. :)
Dell T5810. Harrison Mixbus 32C. Haven't used PT since 2015 and never been happier. |
#25
max performance or capacity?? So if I go whith 6 match sticks I would be even better. Do I understand right???? excuse my english am tryng to do my best.
#26
Well I just looked at the mobile version of the site. All it says is 24gb is max capacity. Whether you get there by 3x8gb or 6x4gb shouldn't make much if any difference in performance.
#27
The same i saw well thanks
#28
IMHO, you should be fine with the 12GB you currently have. When PT goes 64bit, and if you find yourself with a ton of virtual instruments at play, you may (at that time) choose to re-address this.
Oops, I mean 24GB.
#29
The 12gb who has? The op has upped to 24gb. I'm fine with what I have. I probably wouldn't even have 12, but it came with my mobo.
#30
You're right. I usually use less than 10GB, even on really large ReWire sessions.
How to improve the system 5 MC | The golfer | System 5 | 24 | 03-14-2013 06:54 PM |
A Mic Pre That Will Improve my 003 | fooloof | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 5 | 07-21-2009 02:08 PM |
how can i improve my system? | wreckthisplace | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 11 | 01-08-2006 11:21 AM |
what should i get to improve my set up??? | richsorr | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 3 | 05-10-2004 08:33 AM |
improve sound | MG2 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 05-20-2002 02:37 PM |
