Bios changes for improve
In my signature you can see my I7 system
Please can you tellme what changes do in my Bios to improve performamce Think Mostly default For example RAM settings Really thanks
Jascha Koneffke flutist www.prodmusica.cl GA-X58A-UD3R[/ I7 950 RAM 24Gb corsair 1600 (3 sticks) 9-9-9-24 MAC MacBookPro i7 2,3 15" RAM 16gb PT 11.3 003 Rack MBox 3 Pro |
Re: Bios changes for improve
"GA-X58A-UD3R
16GB Mushkin 4GB DDR3 PC3-12800 1600Mhz 9-9-9-24 Blackline" This makes no sense to me. Is it 16GB or 4GB? Either way, its wrong for this motherboard(I run the same one). It runs triple-channel RAM so it should have either 3 or 6 sticks. If 3 sticks, they should all be in the same colored slots(check the mobo booklet for the correct color). The timings look okay. You should also go thru and check the voltage settings to make sure they match that RAM(mine had to be changed to 1.65V on 2 different pages of BIOS)
I'll Check think i have four stick each one 4 gig (1.5)= 16 gig they are triple channel
See and Back
Sorry i have four stick of 2 gig each one
And 2 stick 8 gig each one All 9-9-9-24 1.5 v Triple channel
Well, you are not running triple channel UNLESS you have either 3 or 6 sticks that all match. Since you have 2 sticks of 8GB, I would get a 3rd matching 8GB stick and remove the others. The Gigabyte motherboards USUALLY benefit by setting RAM timings manually(Expert mode). The way to find out if your rig is tuned well is to run the Dverb2 test(see the i7 Builds thread-first page). If your system will score 400 or better, I'd say you in good shape(mine scored 520)
Oh man i must make
clear I have a kit 4x2=8gig If i remove the 2 gig stick What I should do Another 4x2=8gig Or something diferent Or 3 kit 4x2( 6 stick of 4gig Is this better) Sorry i was confused😩
You want either 3 or 6 sticks of the exact same kind of ram. I'm assuming the 2gb sticks are identical to each other and the 4gb sticks also match. So you have some options.
The easiest and cheapest is to remove the 4gb sticks and one of the 2gb sticks. Then make sure the remaining sticks are in the right slots. This is free and gives you 6gb of ram. The next option is to buy a pair of 2gb sticks that are identical to what you already have. Replace the 4gb sticks with these. You'll have 12gb of ram. You could also buy a stick that matches your 4gb sticks. Pull out the 2gb sticks and make sure you have the 3 remaining 4gb sticks in the right slots. Would give you 12gb. You could also buy 4 4gb sticks that match the 2 4gb sticks you already have. That will give you 24gb. The max for that mobo. If the sticks you have now aren't matched you're better starting over. And just buying either 3 or 6 sticks that match. Hope that helps.
Dell T5810. Harrison Mixbus 32C. Haven't used PT since 2015 and never been happier. |
This Is best I think 6 stick of 4 gig i go for It Will be triple channel then....
What do you think about this RAM
Model CMZ8GX3M1A1600C9 Corsair 9-9-9-24willbe 3 single sticks 8gig each one Onother Corsair8gig single stick Vengeance Model CMZ8GX3M1A1600C10 Type 240-Pin DDR3 SDRAM 10-10-10-27 MEMORIA DDR3 G.SKILL RIPJAWS X F3-1600C9S-8GXM 8GB 1600MHZ PC3-1 1,5 v wait you comments thanks
I believe we're still talking about an x58a-ud3r board. If so 4gb sticks is as big as you can go. It can't use 8gb sticks.
How to improve the system 5 MC | The golfer | System 5 | 24 | 03-14-2013 06:54 PM |
A Mic Pre That Will Improve my 003 | fooloof | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 5 | 07-21-2009 02:08 PM |
how can i improve my system? | wreckthisplace | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 11 | 01-08-2006 11:21 AM |
what should i get to improve my set up??? | richsorr | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 3 | 05-10-2004 08:33 AM |
improve sound | MG2 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 05-20-2002 02:37 PM |
