Old 10-25-2011, 10:58 AM
hitshack hitshack is offline
Default Will HDNATIVE Run AAX Native?
when support for TDM and RTAS has ended?
Thank you
Old 10-25-2011, 11:02 AM
nst7 nst7 is offline
Default Re: Will HDNATIVE Run AAX Native?
Yes. If there's no rtas, no tdm, and it didn't run aax, what would it run?
Old 10-25-2011, 02:19 PM
Pardon my ignorance.
Is'nt RTAS the same as Native?
When TDM and RTAS support is ended will that mean the end of RTAS plugs for HDNATIVE?
Old 10-25-2011, 02:29 PM
Dism Dism is offline
RTAS is a native plugin but it isn't 32 bit. AAX is meant to be the replacement for both RTAS and TDM, and can be recompiled for 64 bit and other new features like offline bouncing and freeze tracks. Pro Tools 10 is the transition between the new and the old, so you can use all 3 formats.
D
a n t h e I n c r e d i b l e S o u n d M a n
"Svetlana" v1 - 4.2GHz i7, 16GB RAM, OSX 10.7.4
Liquid Saffire 56 - PT10.2 - BFD2, VCC, Duende Native, Play 3.0
_C U R R E N T-D V E R B-S C O R E:515
Carl Lie Carl Lie is offline
yes. AAX plugs will come in both native and DSP versions. If you have HD native then you can run the native versions. If you have an HDx card then you can run both.
Carl
PT 2018.7 HDX OMNI+HDX8x16 -Mac Pro 12 Cores 48 GB RAM OS 10.12.5 - API 16 channel - AMS Neve 16 channel, AMS-Neve-SSL-GML -Pres/Processing, Bock Audio, BLUE Bottle, Neumann, Josephson -Mics, Bogner, Kemper- Guitar, Chandler Zener-Curve Bender Outboard/Master. UAudio, Waves, Plugin Alliance etc.
Old 10-25-2011, 02:52 PM
So Native AAX will run on HDNATIVE?
Old 10-25-2011, 03:07 PM
TOM@METRO's Avatar
Yes.
~ tom thomas
Formerly hobotom
Pro Tools Ultimate 2019.6 HDX
HD Omni and 192 I/Os
Windows 10
Intel Hexcore i7
All Samsung Pro SSDs
Ampex MM1200 2" 24 trk tape
www.metrostudios.com
Old 10-25-2011, 03:59 PM
Top Jimmy's Avatar
Originally Posted by TOM@METRO View Post
Yes.
Actually, no. HD Native does not have DSP dedicated to running plugins so HD Native will not run AAX DSP plugins.
The real question is whether HD Native will be supported beyond PT 10. I have seen nothing definitive on the matter. The only thing I have seen is that there is a hardware crossgrade available for HD Native to HDX.
James Cadwallader
Hackintosh - Gigabyte Z77X-UP5TH, Intel Core i7-3770K, 32GB 1600Mhz DDR3, 2x SATA 6Gb/s 240GB SSD, 3x SATA 6Gb/s 1TB HDD, 1x Glyph 2TB USB3 HDD, Sierra 10.12.6.
Pro Tools HD 2018.12, Focusrite Red 8Pre, Mbox 3 (Mac)
Pro Tools 11.3.2, Mbox2 (Win 7)
Old 10-25-2011, 04:10 PM
He didn't ask about AAX DSP....
D
Old 10-25-2011, 04:21 PM
lexaudio lexaudio is offline
I believe RTAS is 32bit on a Native system. Its not 64 bit compatible though.
It would have to run through a "bit bridge", and those just don't work well.
Does HD native or native native disable plugins when monitoring inputs? BasketCase Pro Tools HDX & HD Native Systems (Mac) 7 05-20-2013 08:48 AM
upgrade from HD3 to HDnative LFO Pro Tools HDX & HD Native Systems (Mac) 2 09-14-2012 11:26 AM
HDNative (with card) upgrade cshaw Pro Tools 10 2 10-26-2011 08:52 AM
HDNative + Blackmagic Video Ref Issues BobbyDazzler Pro Tools HDX & HD Native Systems (Mac) 6 03-14-2011 02:37 AM
SSL4000 native/ Renmaxx native/ DUY everpack native!!! cary chilton 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 03-22-2007 07:58 AM
