Old 12-10-2010, 12:28 PM
Numi Numi is offline
Default Heat? or Something Like it?
Anyone know of something similar to Heat or the Like that helps add that warmth to our ITB mixes?
I really like the whole idea of it..but from what I have seen, it seems to be more of an HD feature of sorts.
Any suggestions?
Equipment:Mac Mini(Late 2012) and Mbox 3
Audio Drive:OWC TIChip924/FW800
Software:OSX 10.8.5, Pro Tools 11.0.2/10.3.7, Reaper 4 and WaveLab 7
~On The LeVeL~
Old 12-10-2010, 12:33 PM
Carl Lie Carl Lie is offline
Default Re: Heat? or Something Like it?
Slate VCC will be out shortly I hope and if you had cash to burn you could buy a Hedd 192 for conversion and use the DSP on that to emulate tape and other distortion.
Carl
PT 2018.7 HDX OMNI+HDX8x16 -Mac Pro 12 Cores 48 GB RAM OS 10.12.5 - API 16 channel - AMS Neve 16 channel, AMS-Neve-SSL-GML -Pres/Processing, Bock Audio, BLUE Bottle, Neumann, Josephson -Mics, Bogner, Kemper- Guitar, Chandler Zener-Curve Bender Outboard/Master. UAudio, Waves, Plugin Alliance etc.
Old 12-10-2010, 12:41 PM
nst7 nst7 is offline
+1 for Slate VCC.
Old 12-10-2010, 12:42 PM
Dism Dism is offline
Originally Posted by nst7 View Post
+1 for Slate VCC.
Ditto.
D
a n t h e I n c r e d i b l e S o u n d M a n
"Svetlana" v1 - 4.2GHz i7, 16GB RAM, OSX 10.7.4
Liquid Saffire 56 - PT10.2 - BFD2, VCC, Duende Native, Play 3.0
_C U R R E N T-D V E R B-S C O R E:515
Old 12-10-2010, 01:12 PM
Keybeeetsss's Avatar
Keybeeetsss Keybeeetsss is offline
Ditto to the +1 & ditto..
But I will say this; VCC is emulating Consoles, not tape; so if u want something thst emulates tape, check out SATV by Mellowmuse; that along with VCC is the perfect combo; or UAD & VCC...
MYSPACE ON'EIM
LAUTEN MICS & ME
DA'TUBE ON'EIM
'IS TAMARA HOME'
NO, SHE'S WITH
HOBO KEY
'' (that dopey green thing)
('we' must start using pronouns)
Old 12-10-2010, 01:13 PM
Craig F Craig F is offline
A800
http://www.uaudio.com/products/softw...800/index.html
PT11 System Requirements link http://avid.force.com/pkb/articles/C...m-Requirements
Thank you,
Craig
Old 12-10-2010, 01:28 PM
That looks cool. How are the UAD plugs running in PT these days?
C
Old 12-11-2010, 12:17 PM
I took a look at both of these..and I think SATV is more of what I was thinking.
Not bad for $99 buckos. The reason why I bring this up..is I work in a Starbucks..and I have the displeasure/or pleasure depending on what is on..to hear a lot of newer music and older. I notice..the difference between the two, depending on who, when, and where it was recorded seems to be clarity(sometimes plain or harsh) and warmth(whatever that is ).
I don't want my tracks, to fall in one or the other..I would like to be able to get the best of both worlds with my pathetic wage..Can't afford HD much less need it or the equipment..so this is why the SATV plug in from mellowmuse has my attention. Thanks guys for the advice.. this looks like a wiener
Sidenote: I have come to the conclusion, that most music ends up pretty bastardized and destroyed by the time it hits places like Starbucks. From what I have found personally...the audio quality is something like mono/48k/mp3 128 bit rate. So who knows if what I'm hearing is even being represented well. The irony from all this..is I never ever ever hear..anyone ever... complain about the quality of that "mix.." or the quality of that "recording". It's hum the hook and buy whatever is in at the moment, and then eat up more media tomorrow just the same.
~On The LeVeL~
Old 12-11-2010, 01:37 PM
TOM@METRO's Avatar
I use SATV at least somewhere on every session now.
~ tom thomas
Formerly hobotom
Pro Tools Ultimate 2019.6 HDX
HD Omni and 192 I/Os
Windows 10
Intel Hexcore i7
All Samsung Pro SSDs
Ampex MM1200 2" 24 trk tape
www.metrostudios.com
Old 12-11-2010, 02:26 PM
Tom..I notice you do Tape Recording also. How does the SATV plug in do in your opinion when it comes to it's Tape Setting? I'm curious, being that you obviously have an ear for this sort of thing? I'm really looking to be able to warm up vocals, and mic'd acoustic guitars and such.
Could I insert it in WaveLab 7 and set it on Tape and get the emulation of what You consider Tape-Like sound?
Or, should I just insert it on any track, I feel could use a bit of that type of sonic character and then mix like that? Or Both?
EDIT: Also, what do you think of the Massey Tape Head plug-in?
~On The LeVeL~
[IMG] code is Off
Does comping to a Heat enabled track print the Heat? joshdrucker macOS 0 03-12-2014 10:17 PM
Something like Heat for LE? DonaldM Tips & Tricks 15 02-04-2011 02:20 PM
Can I use heat in PT HD 9 with a 003? evertonlouvize Pro Tools 9 11 01-21-2011 09:19 PM
HEAT and PT 9 non-HD chicken Pro Tools 9 1 11-10-2010 06:43 AM
Heat vs VCC nwilson@hns.com Pro Tools TDM Systems (Mac) 24 11-01-2010 05:36 PM
