Old 10-21-2010, 07:34 AM
Fidelis Fidelis is offline
Default Re: HEAT, NEVE 8048 Listening Challenge
Ok Tom,
Took the test:
You scored 60 % Correct
Most correctly identified : Pro Tools mix with HEAT (5 out of 5)
In Section 5 You Preferred the "Pro Tools mix with HEAT", 206 People have taken the test to date and 69 % answered A/B said They were not sure - It was Pretty hard.
Well... it looks like I have to buy HEAT... But I just bought VCC...
http://www.ricardomosca.com
Hackintosh, 3,7 GHz 10-Core Intel i9, 64 GB 3200 MHz DDR4, OSX Catalina 10.15.7, PT HDX 2023.9.0, SSL 4040G+, tons of outboard
Mac Book M1 Pro, 16GB RAM, OSX 23.6, PT Studio 2023.9.0
Old 10-21-2010, 07:39 AM
Samuel Axelsson Samuel Axelsson is offline
66% and PT with heat 4 of 5 correct. It seems it has a sound...
Old 10-21-2010, 06:11 PM
wizprodux wizprodux is offline
Tom,
What setting did you guys have on HEAT (Drive & Tone) ?
Old 10-21-2010, 09:02 PM
Tom Graham's Avatar
Tom Graham Tom Graham is offline
I believe the setting we ended up on was Drive at about 10 o'clock and Tone at around 2:00 o'clock. An interesting thing was, we settled on using HEAT on the source channels and on the Audio Stems that they were feeding as well. In essence, double HEAT. We felt that this was appropriate because if you were doing the Stem thing either to tape or back into the console, you were getting double the 'effect' of the tape or console.
Tom Graham
Avid Audio Marketing
Pro Audio and Mixing
[email protected]
Check out our Pro Mixing Webinars :
http://www.avid.com/US/resources/pro-mixing-webinars
Avid Pro Mixing Blog:
http://www.avidblogs.com/promixing/
Old 10-21-2010, 09:06 PM
Tom Graham's Avatar
I just checked, as of right now :
288 People have taken the test to date and 68 % answered A/B said They were not sure - It was Pretty hard.
The Current Average Score is 30 % Correct.
Tom Graham
[email protected]
  #16
Old 10-21-2010, 09:36 PM
Yea!!
My fav setting it DRIVE 9 o'clock and TONE 1 o'clock.
I set this up before starting my mix and then I often crank the output of the EQ of my individual tracks to get some of that HEAT distortion, especially on overheads and kick and snare!
http://m.youtube.com/?dc=organic&sou...&v=AqLl2DfDy9E
  #17
Old 10-21-2010, 10:14 PM
SOUNDDECISION SOUNDDECISION is offline
Wouldnt it be better to ask "pick the best sounding A, B or C. " for each section Since without a point of reference its hard to have any idea how you have heat set. Are you making it Brighter , Darker etc...
This isnt really a good test to figure out which is the best sounding since you spend the whole time trying to guess which each one must be rather than just focusing on picking the best sounding mix.
They clearly sound different and better and worse but that doesnt necessarily translate into identifying what each one must be.
Also the mix files are very low quality... is this a low rate Mp3? Is it possible to get a fuller sounding mix to compare?
This is a great idea tho...
  #18
Old 10-22-2010, 08:30 AM
kinghand kinghand is offline
Most correctly identified : Pro Tools mix with HEAT (4 out of 5)
In Section 5 You Preferred the "Neve summed Pro Tools mix", 377 People have taken the test to date and 64 % answered A/B said They were not sure - It was Pretty hard.
  #19
Old 10-22-2010, 08:34 AM
digidesigner digidesigner is offline
I think we are getting these kind of similar results because HEAT mixes have slightly more top end = better
  #20
Old 10-22-2010, 09:20 AM
Tom Graham's Avatar
The mixes you downloaded are dithered 48k 16 Bit files. There really is no easy way to make a 96k 24 Bit Video QuickTime file, I tried to. 48k 16 Bit is not much different than any other CD, except these are not mastered versions.
The point of the test really is, they are all cool and close. If the NEVE (Analogued Summing) mix was hands down better, it would be obvious for people to hear and they would pick that mix as their favorite. To me, the average score of 30% means people can't really hear the difference, it's slightly less than 33% if you randomly pick 3.
If anyone in Los Angeles wants to schedule a time to hear the full 24/96k mixes, I'm sure we could set up a time in our Burbank office... Email me after AES.
Also - I will try to bring the files to the AES show in San Fran.
Thanks guys!
Tom Graham
[email protected]
Does comping to a Heat enabled track print the Heat? joshdrucker macOS 0 03-12-2014 10:17 PM
HD6 vs HDX2 "ITB" Listening Challenge Tom Graham Pro Tools HDX & HD Native Systems (Mac) 131 12-19-2012 03:45 PM
HD6 vs HDX2 "ITB" Listening Challenge Tom Graham Pro Tools TDM Systems (Mac) 0 11-01-2012 08:17 PM
Heat challenge issue... hmmmm... velvettone Pro Tools TDM Systems (Mac) 10 12-06-2010 04:46 PM
heat vs neve summing test ericlees Pro Tools TDM Systems (Mac) 1 10-30-2010 07:14 PM
