Old 07-12-2009, 05:44 PM
azuraman azuraman is offline
Default Front Panel DI on 003+ not working.
Hello there.
Basically my problem is when I plug into the front panel DI, no signal goes into protools. Since the DI overrides the rear input of Channel 1, both inputs on the rear work. But when I do plug into the front DI, the rear input are disabled. Im not sure if its an internal routing issue or what. Can someone help.
Old 07-12-2009, 06:30 PM
Default Re: Front Panel DI on 003+ not working.
Have you tried both positions on the Line/DI switch for channel 1?
Old 07-12-2009, 06:49 PM
Yes I have. Doesn't matter if it is either mode.
Old 07-13-2009, 12:05 AM
That's a head scratcher. Did you unplug the rear? Just wondering if the over-ride works both ways(heck, its worth a try). I guess you can use a Direct Box and go into a mic input(XLR). I've been tracking bass thru an Aphex Punch Factory with great results(its a combination DI and opto compressor).
Old 07-13-2009, 03:29 PM
Yeah I did with the same results. Its got me beat. Its a real head scratcher. It has never worked since I got it. Don't know what else to try.
Mbox Pro some front panel buttons not working! azah FireWire and USB Audio Interfaces (Win) 1 07-29-2015 03:33 AM
How do I select the mic input on the front panel...got it! Sam C Eleven Rack 0 01-17-2012 02:13 PM
Firewire led on front panel is red!!!! SMO500 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 5 06-29-2006 01:22 AM
OT, different colored front panel for 001 ???? Bob Legs 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 15 07-19-2003 12:33 AM
front panel gain closeriget 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 12-05-2001 09:45 PM
