  #21
Old 02-20-2007, 11:41 AM
emilano emilano is offline
Default Re: A new & free helper application for ProTools
Willard inspired me to get into the automator. By using it and also writing a simple little applescript file I was able to make an app that did everything this app does but also empties the trash and restarts for you. very cool, thanks for the inspiration...
  #22
Old 02-20-2007, 02:39 PM
docric docric is offline
Thanks JC!
Anything that can save some time is appreciated!
-C' ya'
Rick
MacPro 6,1; 12 core; 64 Gb RAM; 1 TB Samsung 970 Pro w/ adapter & heatsink; OSX 10.14.5
PT 2019.6.0 Ult.
Burl MS / PT Dock/ Eucon 19.7.0/iPad Air2/ iOS 12.3.1/ProTools|Control
  #23
Old 02-21-2007, 01:13 AM
25ghosts 25ghosts is offline
thank you SOOOOO much for posting this.... I had made an apple script but as I am not much of a programmer it worked really badly. Your app is great and I use it a lot (Unfortunately)
Thank you
2016 MacBook Pro Retina | 16GB RAM | 1TB SSD | OS X Latest - PTHD 12 Latest | 4K LG Thunderbolt Display | Logic Pro 10
  #24
Old 02-21-2007, 04:48 AM
Just a small idea:
maybe add a button deleting /library/appllcation support/digidesign/databases/Volumes/(all the contents)
Sometimes deleting the contents of this folder alone does the trick
  #25
Old 02-26-2007, 09:45 AM
studiojimi's Avatar
studiojimi studiojimi is offline
this is potentially too good to get buried..it should be a sticky shouldn't it?
CAZADOR RECORDING
PT10.3.10/HD6/192w16in/MTN.LION OS 10.8.5 / Westmere MacPro 8 Core W/20gRAM MAGMA-PE6R4/TDM&RTAS/WAVES Platinum/UA/Eventide Plugs/I usually record at 88.2
With GOD as my partner. . . I need to make my plans LARGER.
  #26
Old 02-26-2007, 09:58 AM
smlworld smlworld is offline
sticky. sticky. sticky.
[img]/images/graemlins/tongue.gif[/img] <<<<< in the psychiatric emergency handbook this is bad news.
  #27
Old 02-26-2007, 10:27 AM
nikki-k nikki-k is offline
Thank you, thank you, thank you for this!
nikki k
Eagles may soar, but weasels don't get sucked into jet engines.
On the other hand, you have different fingers.
Originally Posted by nikki-k View Post
Sometimes ya just gotta put your tongue on the 9V battery just to see what all the fuss is about.
  #28
Old 02-26-2007, 12:34 PM
JC925602 JC925602 is offline
I'm making the version 2.
Instead of a big button with predefined files, it will be a BIGGER BUTTON with check box on the side to select a custom set of files, plus a backup/restore preferences option (but not for the Digidesign Database folders -a V3 feature-), and maybe an icon and a French translation.
It will include the ~/library/application support/digidesign/databases/Volumes, ~/library/preferences/ByHost/com.apple.Midi.1231xxx.plist, ~/audio/Midi Configurations.
Am I forgetting something?
JC
  #29
Old 02-26-2007, 12:38 PM
mik mik is offline
Does this work for Panther and Tiger ? For LE also ?
Thanks
  #30
Old 02-26-2007, 12:44 PM
It's supposed to as all the separate scripts where working with 10.3, 10.4, PT 6.x and 7.x TDM and LE.
JC
Can't find Pro Tools 8 prefs to delete in Mountain Lion Cartoonguy 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 08-18-2012 09:48 AM
trash database and prefs in P T 8 ??? not2tech Pro Tools TDM Systems (Mac) 1 10-06-2009 12:32 PM
I delete prefs and the Database open session then system crashes 8.0.1 philip888 Pro Tools M-Powered (Win) 8 09-10-2009 06:42 AM
Free Pro Tools Application - Delete Prefs/Database JC925602 Pro Tools M-Powered (Mac) 1 03-21-2007 03:04 AM
Free Pro Tools Application - Delete Prefs/Database JC925602 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 5 03-18-2007 11:20 AM
