Old 06-13-2009, 02:40 PM
confusedhelp confusedhelp is offline
Default How to properly setup the original Mbox with the MOTU 828mkII for monitor control
Hello,
My question is, actually it's more am I doing this right, since the original Mbox (2002) does not have a monitor control. I would connect the cables like this? (see link for pictures)
Mbox line output (TRS) 1 & 2
http://www.record-producer.com/i/dig...-mbox-rear.jpg
GOING INTO
MOTU 828mkII Balanced/Unbalanced 24-bit 96khz Analog Inputs 1 & 2
http://www.majormusic.com.au/images/..._small_rgb.jpg
Then connecting my speaker monitors to the MOTU 828mkII Main Out Left & Right
correct?
Thank you!
Old 06-13-2009, 03:02 PM
ankely ankely is offline
Default Re: How to properly setup the original Mbox with the MOTU 828mkII for monitor control
I run a MBox and a MOTU828.
Out of MOTU828 ch 7&8 into MBox 1&2.
Out of MBox 1&2 into MOTU828 7&8.
I then set up, using the MOTU Audio Setup, the MBox as the Monitor In.
This way the MOTU828 is the hub to go to monitors etc. and I can monitor the MBox and record to the MBox from the MOTU828.
I record into the MBox via MainStage and/or Waves GTRSolo for guitars, etc.
Hope this helps.
Pro Tools 10.3.9, MBP 2.4GHz Intel Core 2 Duo OS 10.6.8 4GB/Ram, 7200RPM 750GB Internal HD, Focusrite Saffire Pro 40, Digidesign Mbox 2.
It is what it is...
ScrewMakerMusic
Old 06-13-2009, 03:53 PM
Hope this helps.
Thank you, that helped
but would my setup connection do just fine or am I missing something here?
Old 06-13-2009, 04:03 PM
Cool Re: How to properly setup the original Mbox with the MOTU 828mkII for monitor control
I picked I/O 7&8 as to keep 1&2 on the MOTU828 open for guitar and vocal mic inputs.
I also felt that 7&8 keeps it a bit more idiot proof (feedback lops and other things) and keeps the MBox and it's audio routing a bit more flexible and independent from the MOTU828.
Hope that helps.
It is what it is...
ScrewMakerMusic
Old 06-13-2009, 04:54 PM
Hope that helps.
Makes sense to pick Input 7 & 8
But from my above question, my connection would work just fine?
Thanks!
Old 06-13-2009, 04:57 PM
Yup.
But probably better to plug the MBox into 1&2 on the back of the MOTU.
I'm reading the MOTU site, and it's not really clear if there is a difference between the line inputs in back vs. front.
Front does say MIC/GUITAR where the back are line inputs.
Double check with your manual, as I do not have one for the 828MkII (I've got the older version).
Confused myself. Hope this helps.
It is what it is...
ScrewMakerMusic
Old 06-13-2009, 05:01 PM
Yup.
Awesome. Thank you ankely
How do you like your Mbox+MOTU 828mkII combo?
Old 06-13-2009, 05:10 PM
I like it.
The only time that it's a PITA is if I want to record thru Digi plugins.
That doesn't work to good for guitars and vocals as the MBox has a pretty high latency.
But, for recording thru the plugins from MainStage or GTRSolo it works awesomely. I set the MOTU to a 64 buffer. Leave the MBox/Pro Tools set to a 1024 buffer and use the mix control on the MBox to create a blend of the tracks from Pro Tools and the inputs from the MOTU when recording.
Gnarly !!!
It is what it is...
ScrewMakerMusic
Old 06-13-2009, 07:14 PM
Yup.
Those inputs at the FRONT panel are for Mic/Guitars
I was referring to the rear inputs
see link: http://www.miafrica.co.za/graphics/m...--CROP-OPT.gif
As you can see those rear inputs are for standard TRS cables (which would connect to the TRS output of the Mbox), which this thread pretty much answered my own question
Old 06-13-2009, 07:17 PM
Cool !!!
Then it should be all good.
It is what it is...
ScrewMakerMusic
HD OMNI to replace MOTU 828MKII maxwell_ Pro Tools HDX & HD Native Systems (Mac) 12 02-07-2014 04:28 PM
Motu 828mkII with PT 10 Snickerz Pro Tools 10 2 06-16-2012 05:11 PM
Profire 2626 and Motu 828mkii with PT 9 matocaster1202 Pro Tools 9 7 01-25-2011 08:54 PM
Does Motu 828mkII work with pro tools? kraaag 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 8 02-11-2004 02:02 AM
MOTU 828mkII - if it could only run PTLE j old school 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 05-15-2003 10:30 AM
