Old 06-01-2015, 05:53 PM
CDay63's Avatar
CDay63 CDay63 is offline
Default PT12 and 48k
I just crossgraded to PT12. I tried to open a session that I recorded in a previous version at 48k and PT says "Can't open a session in that resolution." Ugghh... Anyone have a solution? How do I tell PT to use 48k? I'm on Windows 8.1, 64 bit.
CDay
Windows 10, MBox 2
Pro Tools 12.4.0
Old 06-01-2015, 06:55 PM
Brandonx1 Brandonx1 is offline
Default
What audio I/o are you using? You might need to change the sample rate of the card first, then open pt and then open the session.
Brandon Howlett
Vibe Audio Post, Inc.
Re-recording Mixer
Custom Build CPU, HDX 1, Omni, 192 I/O Digital
S6 M10 24 fader
Satellite Mac Pro, HDNative, 192 I/0
Black Magic HD Extreme
Old 06-02-2015, 10:54 AM
The Weed's Avatar
The Weed The Weed is offline
Default
Go into Sounds and make your onboard soundcard the default for Windows audio/sounds, leaving the MBox 2 for Pro Tools only.
Cheers,
non-union national read at a reasonable rate
Demos: brucehayward dot com
Source-Connect: brucehayward
Old 06-02-2015, 10:04 PM
Amack Amack is offline
Default
So far this has always worked for me! http://duc.avid.com/showthread.php?t=368422
Old 10-04-2015, 09:34 PM
CDay63's Avatar
Default Re: PT12 and 48k
Thanks all for your help.
CDay
Windows 10, MBox 2
Pro Tools 12.4.0
PT12 and PT12 HD surround? theom Pro Tools 12 17 10-12-2015 09:27 AM
No PT12 available giacomopasquali Pro Tools 12 9 05-12-2015 04:12 AM
Best OS For PT12 spoons Pro Tools 12 3 04-09-2015 07:57 PM
Pt12 hd Reckless Erik Pro Tools HDX & HD Native Systems (Mac) 4 04-08-2015 04:21 PM
