Go Back   Avid Pro Audio Community > Pro Mixing > Avid S6
Old 03-13-2014, 09:30 AM
paulo m's Avatar
paulo m paulo m is offline
Default Old XMon on S6?
Can a XMon that´s been in use with a D Command, still be used when upgrading to the S6? I´ve been seeing references to XMon S6 but I´m wondering about the diferences, since the user manual is almost a copy from the "old" XMon.
Thanks.
Regards,
Paulo M
Old 03-13-2014, 10:01 AM
Drew Mazurek's Avatar
Default Re: Old XMon on S6?
Thanks.
It is the same unit.
www.drewmazurek.com
Old 04-03-2014, 12:04 PM
tundra tundra is offline
Our XMON doesn't seem to work..
Beta Test!
Old 04-03-2014, 12:09 PM
Craig F Craig F is offline
Might need firmware
may require the MIDI adapter to do it
PT11 System Requirements link http://avid.force.com/pkb/articles/C...m-Requirements
Thank you,
Craig
Old 04-03-2014, 12:45 PM
Oh the app works, and it connects to the S6 (won't stay locked though) it just doesn't actually pass any audio.
So we're just using the analog out of our omni and putting a master fader
in every session in protools.
Old 04-04-2014, 03:34 AM
black_coffee black_coffee is offline
It sounds like the software is not communicating with the XMON. There is no reason why it shouldn't, but as the XMON uses MIDI to commmunicate with the XMON software, it is likely a MIDI setup issue.
I would take advantage of that first year support that comes included with the S6 and contact Avid.
Oh... and to lock the XMON app to the surface, when focused on the app, press the top Setup button in the monitor control surface section of the MTM (just below the OLED near the Avid logo).
Old 04-14-2014, 09:18 AM
Xmon is permanently muted.
Old 04-14-2014, 11:03 PM
DigiFieldService DigiFieldService is offline
Tundra,
Do you mean that the XMON front-panel Mute switch is always on? That would indicate that there is a communication problem (probably a MIDI issue).
If the front-panel Mute light is not lit up, then are you on S6 software 1.1.1 yet? If so, you should now see the Speaker Outputs available at the bottom of the Monitoring window. Make sure you have your speakers enabled, and your source chosen at the top.
-Rich
Old 04-24-2014, 06:00 AM
ShadeTek ShadeTek is offline
Our X-mon had this problem too. There are two fixes that may hekp you. In the X-mon app, select and deselet the main/mini monitor check boxes. If that doesn't work, turn your speakers off and then turn the monitor volume control round on the S6 full whack then back to zero. Then switch your speakers back on.
Old 05-26-2014, 08:32 PM
hyjek hyjek is offline
Still having the same issue as stated above with the S6 & XMON. Has anyone found a solution yet? None of the suggestions given have worked for me.
Need XMON help AINSLIE ICON & C|24 9 05-31-2012 11:51 PM
Xmon?? bstroner ICON & C|24 5 04-01-2009 05:47 PM
XMON for your DAW Mike Landolt General Discussion 1 04-13-2006 03:04 PM
XMON tstemland ICON & C|24 2 03-23-2006 02:00 PM
XMON OKN ICON & C|24 2 01-27-2006 09:34 AM
