Go Back   Avid Pro Audio Community > Pro Mixing > Avid S6
Old 12-05-2016, 11:36 PM
jp.donnelly jp.donnelly is offline
Default Inserts & Sends
Hi all,
Is there any timescale on when we'll be able to instantiate inserts and sends directly from the S6?
We "upgraded" two of our rooms (we're a Higher Education provider and ALP) from C24s to S6's and the features missing from the S6 (sends and inserts being the big two) are just mind boggling. The feel, softkeys and so forth make the S6 a wonderful upgrade, but not being able to add sends and inserts just boggles the mind!
Old 12-06-2016, 12:07 AM
Drew Mazurek's Avatar
Default Re: Inserts & Sends
Originally Posted by jp.donnelly View Post
Hi all,
When one considers that the S6 is mostly aimed at Post work, and their reliance on templates, it's easier to understand the omission. IOW, if all your sends and inserts are already there, there's no need to be able to assign them. Is your mind "unboggled"???
No excusing it or saying you don't have a point, just trying to help you understand why it might be this way.
www.drewmazurek.com
Old 12-06-2016, 01:27 AM
I understand that, but as a replacement to the Icon, which was used in mixing facilities, too, you'd think there'd be more mixing functionality. Being able to exmake and a plugin over multiple channels is fantastic. Being able to assign sends and inserts like you can inputs and outputs would've been the cherry on the cake IMO.
Old 12-07-2016, 07:45 AM
EddieJones's Avatar
Definitely on our to do list, once we get a few other things done first.
Old 12-20-2016, 05:47 AM
Like naming the sources ?
~ Trashcan Mac Pro late 2013 - 64 GB RAM - 10.12.6 / Pro Tools Ultimate 2019.6 / HDX 2 + UAD2 PCIe OCTO in Magma Expressbox 3T / HD I/O's x 4 + 1 x 96io / Avid S6 M10-24-5 V19.12 ~
~ MBP 15" 2.8 Intel Core i7 -10.12.6 /Apollo 16 / Steinberg U22 / Artist MIx / Pro Tools HD 12.8.3 - UAD2 V8 / UAD2 Satellite DUO ~
~ Mac Pro 8 core - clover - 13 GB ram - 10.6.8 / HD5 / Pro Tools 9.0.6 / HEAT / Magma PE6R4 / ProControl 24 faders / UAD2 QUAD PCIe ~ ARCHIVE RIG
~ Mac Pro (Early 2009) - 2 x 2.26 GHz Quad-Core-32 GB RAM-10.13.6 / Pro Tools Ultimate 2019.10 / Apollo 16 / Avid S3 ~
Old 01-05-2017, 11:01 AM
creativecontrol's Avatar
Like automagically binding XMON or MTRX (AX32).
Jeff Komar
Old 01-05-2017, 12:36 PM
rus5 rus5 is offline
Hi Drew!
Wow!! Reading your post sent CHILLS down my spine!! "... mostly aimed at Post work" ?!?!? I may be completely missing it here but I think I could go back and find Avid ads, Avid statements in this forum, Avid presentations at conventions and conferences, Avid videos, etc that clearly describe the S6 as the perfect MIXING solution (along with being the perfect Post solution). And that it is intended to replace their previous mixing targeted products. I can at least say for sure a whole lot of us definitely had that impression.
Even without knowing you, I can assure you that you are FAR more knowledgeable about all of this than I am (which is why your comment was so scary). But from my point of view, I wouldn't have thought that a focus on Post (vs. say mixing, or tracking...) is, or should be, driving any Avid choices regarding what features should be included in S6 software updates. Did I buy the wrong thing??
PS. I've been feeling the same way as JP about inserts and sends and I think others have too??
Old 01-06-2017, 02:09 AM
Originally Posted by rus5 View Post
Hi Drew!
Same, Russ.
We were in conversation with Avid at the time of purchasing and fully explained our needs. These were a replacement to two of our C|24's that we used for tracking and mixing, sure adding inserts and controlling plug-ins was clunky, but sends weren't. It's quite concerning to think we've parted with over 30k on two S6's to now be told what we're using it for isn't priority for Avid, and knowing the turnaround timescale for a lot of Avid's fixes, the concern is only accentuated.
Has anybody else noticed that the modifier keys appear to not function correctly? Setting inputs in batches (i.e all inputs to input 1) used to be a simple assign whilst holding alt on the C24, but on the S6, it doesn't seem to work the same way.
Old 01-06-2017, 02:58 AM
Guys,
I'm just a user like you are. I don't work for or speak for Avid. Sorry if you mistook my attempt at explaining possible motivations for an omission as subterfuge. I too would have expected complete ICON parity and then some by now, which is why I am not an S6 owner. Once it actually suits my needs, I'll buy. (I do get to use them at various studios though)
I did enjoy Russ's little dramatic post though, thanks!! :)
www.drewmazurek.com
Old 01-06-2017, 12:08 PM
Guys,
Gosh Drew, I wouldn't say I was being "dramatic"? Describing my post as a "... little dramatic post..." is a bit condescending, don't you think? I spent $60K out of my own pocket on my S6 based on promises Avid has been making for YEARS now that I don't feel have been kept. Obviously a lot of other folks feel the same way. That is one HELL of a lot of money to me. Your original post almost sounded like a possible explanation for what I was seeing (that the S6 wasn't ever even INTENDED for my purpose in the first place and somehow I got that wrong), from a far more experienced user than me, and I was merely asking about it.
inserts vs. sends. Terry Wetzel Pro Tools 9 3 11-30-2014 09:10 AM
sends inserts. what the f&)&)&k lionstudios 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 04-06-2007 03:34 PM
Inserts and Sends? pribb1 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 10-26-2003 10:50 PM
Inserts or Sends? MindDead 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 09-20-2003 11:21 PM
Sends before inserts... Why not? Corey Shay Pro Tools TDM Systems (Mac) 4 07-31-2002 10:03 AM
