PT12.6HD edit session to a PT9 mix room translation?
Hey guys, I just found out the mix of a short film I've edited/supervised is going to a mix in a system running on PT9. The mix is Monday morning, any tips on getting as much of my work into the mix? If they install a plugin like Pro-Q 2 that I've been using, is my automation data from my side going to make it through?
Thanks for your help! |
Re: PT12.6HD edit session to a PT9 mix room translation?
Nehalem 2.66 quad core, 32 Gig RAM , 640GB , 2TB Seagate, OSx10.8.5, PTHD10.3.8, HD3 Accel, MidiIO, 192, 96i, Pre |
Also the automation should be printed to the audio tracks, they just won't be able to change any of the automation since it will be printed to the track....moon
No way to get automation across?
How about "Save Copy In" using PT 7-9 and check off Audio and any other parameter you want to include? Obviously some of your plug-ins won't work if they are different in any way from the ones available for PT 7-9.
PT12.6 Bug With New Edit Window Fade Shaping Feature | pdubber | Pro Tools 12 | 3 | 10-06-2016 06:32 AM |
PT12 HD Mark Edit Start is early | PeterScherr | Pro Tools 12 | 3 | 06-08-2015 01:41 PM |
Toggle Mix and Edit windows shortcut bug in PT12? | emj_antonin | Pro Tools 12 | 1 | 05-15-2015 05:18 PM |
Screening / edit room monitor recommendations? | postprosound | Post - Surround - Video | 9 | 12-04-2006 02:17 PM |
HELP! - FOREIGN TRANSLATION SESSION | Don Henry | Tips & Tricks | 9 | 04-13-2001 06:13 AM |
