Go Back   Avid Pro Audio Community > Other Products > Pro Tools Express on Mac OS X
Old 11-18-2013, 03:14 PM
ParkerSL ParkerSL is offline
Default Unable To Locate Hardware
So i have just bought and received my Pro TOols Express and Avid Fast Track Interface. I have registered and downloaded everything including the Instruments and have updated to the more recent update for my interface but every time i go to open Pro Tools Express a message comes up saying "Unable to Locate Hardware" i have no idea what to do at this point. I have checked as many forums as i could find but still can not find an answer to this issue. if someone could help that would be amazing, thank you! also i do have the interface and usb iLok plugged in while trying to open Pro Tools
Old 11-18-2013, 03:33 PM
YYR123's Avatar
YYR123 YYR123 is offline
Default Re: Unable To Locate Hardware
You need to post your computer specs operating systems and the ProTools version that you were using for a more detailed response and help
Daniel
Old 11-18-2013, 07:51 PM
I am using a Mac Book Pro 13' and Pro Tools Express
Old 11-18-2013, 07:58 PM
YYR123's Avatar
Sorry to be a downer but u say mb and I think 10.6.8 - right???
U say PTE and I say ver 3.5 right?
Daniel
Old 11-18-2013, 08:08 PM
2.9 GHz dual core intel Core i7 with 4MB L3 cache
8gb of 1600MHz DDR3 SDRAM
750gb 5400 rpm hard drive
any of that help? im not that ig into computers so im not to sure what to post
Old 11-18-2013, 08:13 PM
Southsidemusic's Avatar
We need:
OS version
Pro tools version
Driver version for your Avid FT interface
Other useful info found here
http://duc.avid.com/showthread.php?t=300050
Please provide ALL the info we ask for in one clear concise post so we don't have to ask several times for your OS version for example
Thank you
Christopher
Best Regards
Christopher
#thestruggleisreal
South Side Music Group
WEBHOME
Old 11-25-2013, 02:05 PM
skugger skugger is offline
FYI, I just ran into this issue with my brand-new M-Track Plus. I only had to download and install new drivers for it, at www.m-audio.com, in order to get this error to go away. the new drivers are dated May 2013.
Old 01-03-2014, 10:58 PM
apoltorak6 apoltorak6 is offline
From what it seems I had the same exact problem, and this was the answer. I looked all over the forums and nothing helped...then I saw this post, downloaded the most recent driver, and now everything works!!!
'Unable to locate M-Audio hardware. Make sure your hardware is connected and turned o roland342 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 10-29-2012 09:01 AM
"Unable to locate M-Audio hardware. Make sure your hardware is connected and turned o MerryD Pro Tools SE and Essential (Win) 8 08-02-2012 12:59 AM
Unable to locate Digidesign hardware. Make sure hardware is connected and turned on. qillster 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 5 02-09-2011 06:49 PM
Unable to locate M-Audio Hardware. Make sure your hardware is connected and turned on ytass Pro Tools M-Powered (Win) 4 11-25-2009 12:49 PM
unable to locate m-audio hardware. make sure your hardware is..works fine in ableton? pein Pro Tools M-Powered (Win) 2 10-07-2009 12:01 AM
