Old 07-16-2006, 11:21 AM
Andrew Red Andrew Red is offline
Default setting up a headphone send
Ive completely forgotten how to set up a headphone send with my 002r so that more than one person can listen and record to the click and music using headphones. If you can refresh my memory thanks alot.
Old 07-16-2006, 01:03 PM
daeron80 daeron80 is offline
Default Re: setting up a headphone send
Well, of course, you need a headphone amp and distribution system of some kind. Assuming that, if you don't mind hearing the same thing the musicians are hearing, the simplest way is to patch from the 002's Main or Alt Main outputs to the headphone amp. If you need to be able to set up a different cue mix from what you're hearing, place a Send-->Interface-->Analog 3 & 4 or whatever pair you prefer, and make them all prefader (enable the "pre" button at the top of each send's fader. The second method is only recommended stronly if you have some kind of fader board interface that allows you to see and quickly access all the sends at once. Generally, I'd rather put up with monitoring the musician's cue mix myself than try to operate a seperate cue mix with just a mouse.
David J. Finnamore
PT 2023.12 Ultimate | Clarett+ 8Pre | macOS 13.6.3 on a MacBook Pro M1 Max
PT 2023.12 | Saffire Pro 40 | Win10 latest, HP Z440 64GB
How to send my mains mix to a headphone amp? Johnrg 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 03-13-2014 11:37 PM
Headphone cue send setup in Pro Tools... thoughts? keevhren Pro Tools TDM Systems (Mac) 1 05-28-2011 04:36 PM
template headphone send for 003 PTLE8? redchair 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 10 05-31-2009 11:40 PM
headphone send muted by low latency? Arrgghh... Idahoguide 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 01-01-2008 07:12 PM
control 24 studio headphone send issues tom devilution ICON & C|24 2 10-17-2007 06:44 PM
