Old 06-14-2017, 01:47 PM
Tiberius Tiberius is offline
Default SOLVED. Protools 8 LE working in Windows 10
I wanted to give advice on what I've done to get Protools 8 LE working with Windows 10.
1) Go to Control Panel
2) Sound Settings
3) Disable any and every playback device that may give Protools 8 plugins or hardware an issue.
4) Reload Protools 8 LE and create a session. Note: An error will pop up saying that some plugins and Interlock will interfere but you will click "no" to continue.
I have searched for months for finding a solution, trying to update my system files and I even considered downgrading my PC back to Windows 7 in order to Protools 8 LE to work. All it needed was a simple sound device disable and it started to work. I hope this helps anybody who is looking for a solution. I know Avid has disabled their links to the Protools 8 LE updates and the the download manager won't recognize my device and they haven't released an update yet.
Good luck, hope this helps.
-Tiberius.
Old 06-14-2017, 02:13 PM
sw rec sw rec is offline
Default Re: SOLVED. Protools 8 LE working in Windows 10
Are you on 8.0.5?
Old 06-14-2017, 02:26 PM
29CountsNY's Avatar
29CountsNY 29CountsNY is offline
If you are waiting for Avid to release a windows 10 version of PT 8, your going to be waiting for ever cause it's not going to happen. 12 will be the only version getting updates and that's till they release 13.
www.montabonsound.com
www.29counts.com
Pro Tools HD 2019.12 | HD Native PCIe & HD Native Thunderbolt | Lynx Aurora 16 HD | HD I/O | Digi 192 | 2010 Mac Pro 12 Core 3.46ghz | macOS Mojave 10.14.4 | 48 gigs RAM | Tascam DM3200 | Crane Song Avocet II | Antelope Isochrone OCX | Universal Audio Quad & Duo | Waves Mercury + Studio Classics v10 & Abbey Road Collection
Old 06-14-2017, 02:39 PM
Protools 8 LE 8.00
It works like a charm too.
Old 06-14-2017, 03:17 PM
Interesting! To work on Win 7, you had to install 8.0.3, then the 8.0.5 updater. Then it worked pretty will on Win 7. But if it's working, leave it alone and go to work!!
Old 06-24-2017, 05:07 PM
potsy potsy is offline
Hi there, wondering if you had trouble with the recent windows 10 creators update? My system did the auto update to Windows 10 home version 1703, OS build 15063.413. After that Pro Tools 8.05 would not launch, with the error: "no RTTI data".
I rolled back to the previous version 1607 (build 14393.1358). Everything is ok again.
Old 06-25-2017, 11:15 AM
I actually didn't have any trouble at all once I disabled ALL my audio devices.
That's interesting, I haven't seen that error before. '
My protools version is 8.0.
http://duc.avid.com/showthread.php?t=241631
I hope this thread helps
Old 06-25-2017, 04:19 PM
I believe most of the 8.0.5 update had to do with firewire interfaces, so a UBS Mbox may be fine without it(and, if it ain't broke, don't fix it)
Old 07-01-2017, 01:18 AM
Tiberius, thanks... I ended up disabling the updates in services, that worked fine. But not an ideal long term solution! If we are at the end of Windows compatibility I guess it's either a dual boot system or look for a second hand protools 10.
Albee1952, I think we might be talking about different things? I had trouble with the last window update. The pro tools 8.0.5 update had been going fine.
Cheers!
Mbox mini Protools 7.4 not working on windows 7 64bits 51sth 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 10 05-05-2012 08:21 AM
I have protools 8 working in windows 7 tjrivera Pro Tools M-Powered (Win) 18 03-28-2012 10:43 AM
Protools 9 working with Windows 7 64-bit playground_strifer Pro Tools 9 12 07-11-2011 05:29 AM
Working iSCSI Initiators on MacOSX and Windows for ProTools Norbert Lenz Storage Subsystems 0 09-30-2007 06:58 AM
Low Latency Not Working! Has Anyone Solved This?? orangepopsongs 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 01-24-2007 11:56 PM
