  #21
Old 05-19-2019, 05:11 PM
innesireinar innesireinar is offline
Default Re: Sample Rounding Issue!!!!
Originally Posted by foxes View Post
I know, you'd think they should know what they're doing......
They will give away the pro market to othrer Sw house with this attitude, at the same time Apple will give away the pro market to HP if they will delay the new mac pro
Avid HDX - Avid HD I/O 16x16 Analog - Pro Tools Ultimate 2023.6 - Nuendo 11
Mac Pro 5.1 2 esacore 2.66 64GB Ram - Mac OS 11.7.7
  #22
Old 05-20-2019, 07:35 AM
foxes's Avatar
foxes foxes is offline
It does seem so.
I’ve just seen the new Studio One 4.5 update coming & the features they’ve added seems to me like their gunning for PT particularly the disgruntled users.
Avid need to take note & get bug fixes sorted plus features to stave off the competition.
iMac 27" Late 2013 3.5Ghz i7 32GB Ram 3TB HDD, 1TB SSD Samsung 850 Pro, Movaje 10.14.6, Pro tools 2021.7, 2021.3 & 2020.12 installed. UAD Apollo 8 Quad & Satellite Quad, Reason 10.4.1 & Reason Suite 11.3.9, Logic Pro X 10.5.1 (need to upgrade to Catalina for LPX10.6), plugins & VI's by practically everyone. G-Tech Mini 1TB HDD, 3 x 1TB Glyph GT050Q, Lacie Rugged 500GB & several assorted drives.....lots & lots of hardware synths & outboard
https://soundcloud.com/2b3productions
  #23
Old 05-21-2019, 02:20 AM
It does seem so.
They never will, they never did
  #24
Old 05-21-2019, 12:18 PM
foxes's Avatar
That may be their undoing in some respects. I know Avid have a loyal user base, but that could start shrinking if they stay complacent.
I would love Avid to add more requested features quicker with bug fixes, then I would be that loyal user. But it becomes hard to stay loyal when basic workflow functionality as this thread is about is not there & the competition has so much to offer.
Come on Avid, pull your finger out
  #25
Old 05-24-2019, 03:57 AM
stevegalante stevegalante is offline
Can you guys kindly explain to me what exactly is this midi rounding error ? Came across the audio one sometimes but never the midi.... Thanks
http://www.stevegalante.com
  #26
Old 05-24-2019, 04:36 AM
Downtown_BE Downtown_BE is offline
It's unbelievable. Especially with midi clips that they lose the first note/s when copying. I've noticed that this issue happens when alt>drag for copying. Instead when copying clips by cmnd>c and cmnd>v all seems work properly. I switch back and forth between PT 11 and the last one because PT11 is not affected by this bug, at least on midi material.
yep! my workaround is: quantize before every copy/paste
after quantizing it works but even if you copy/paste 5min later the same thing you have to quantize again
  #27
Old 05-24-2019, 02:25 PM
Since PT 12 it happens on midi clips as well. While on audio material this is not a issue given that you could lose maybe one sample (yes, it creates new clip with +n
) on midi clips sometimes they loses the first note/chord when copying them. The only workaround I found is to copy by cmnd+c and cmnd+v. Very annoying.
  #28
Old 05-24-2019, 02:44 PM
But then why I never met this guy ? Probably because I never use midi clips (I am always in notes view with midi) ?
  #29
Old 05-24-2019, 04:56 PM
You are probabily right, but handling midi without clips it's not comfortable, especially when assembling the song.
  #30
Old 05-24-2019, 05:09 PM
No, believe me, it's just a question of different habits...
Also, for me, if I had to move/copy/repeat/double/etc. midi clips, I would never be 100% sure that all the notes are correctly moved, unless it's all 100% quantized
Sample Rounding budda963 Pro Tools 11 1 07-08-2013 06:07 AM
sample rounding error in pro tools 10??? DarkDayz Pro Tools 10 6 11-02-2011 03:22 AM
PT and Sample Rounding WILL cause Issues when Copying 25ghosts Pro Tools TDM Systems (Mac) 7 07-01-2011 02:25 AM
Sample rounding issues bigdoghat 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 11-13-2007 08:20 AM
Sample rounding, ticks, etc voce Pro Tools TDM Systems (Mac) 1 08-03-2005 05:26 AM
