URGENT disk error / save session copy in.. problem
hi all. we're trying to save a session copy in... of a session to a windows-compatible format. the session we're working off of is already a session that has been saved a copy in... (so its all fresh copies of files). when we go to save it as either .wav or .aif with enforce Pc compat checked, we ALWAYS get a -37 or -50 disk error part of the way through copying the files.
we have tried importing tracks to new sessions, copying to new drives, consolidating audio, pretty much EVERYTHING and we continue to get the errors. anything else we can try? thanks all. -adam-
Mac mini 2018 i7 ProTools Ultimate Native Focusrite Scarlett 18i20 Atmos 7.1.2 hugmonstersound.com / unheardof.world |
Re: URGENT disk error / save session copy in.. problem
You're trying to save to a FAT32 drive? What happens if you save the copy to a local Mac drive and copy that with the Finder?
Rail
I was just having a similar problem...try rebooting your computer into OS 9, open your file using PT 5.3.1, and then try it. You might have better luck...I did.
J |
thanks rail and johnny.
its actually being copied to a mac drive to start with - i believe they will burn a CD and then load that to the windows machine on location... we're currently in os9 / 5.1.3. hope to get digitranslator up and running today to see if an omf will do the trick. any other ideas!?!? -adam-
Check your file names... I ran into a file name on an audio file that was not compatable with PC. I admit that i'm not 100% sure of this, but we renamed some of the files and it worked. It also just might be a bad file somewhere....
cheers georgia
georgia hilton CAS MPSE MPE Hilton Media Management Film Doctors http://www.filmdoctors.com Me... http://georgiahilton.webs.com/ Stage 32 http://www.stage32.com/profile/6569/georgia-hilton My Production Company http://www.hiltonmm.com CREDITS (partial) http://www.imdb.com/name/nm0385255/resume MEMBER: IATSE LOCAL 700 |
thanks georgia. all the file names are pretty normal. i did try making them xxxx.L instead of xxxx L if that makes a difference, and removed parentheses and such, though i don't think those matter. do PCs dislike lots of underscores? some of these files have multiple underscores but i've never seen that be a problem...
keep the ideas coming! digi tech - anything?!? -adam-
Make sure none of the files has a name that is very long (in the 29 character of longer area). That was a problem somewhere back there. Something to do with the new file having to add more characters (.wav) and the result being too long.
Just a guess. HTH |
brilliant, jim! i didn't suspect file name length because it was aborting the copy when the progress box in PT was showing "copying file "violin_01" to...." so i assumed that file was the one that was screwing it up. but there were a few in the session that had longer names - must have been looking ahead and freaking out in advance....
THANKS! now we'll see if it actually loads on this *&$#! xp machine... -adam-
Does "Save Session Copy In" set disk allocation? | Seeee | Pro Tools TDM Systems (Mac) | 5 | 03-14-2007 09:07 AM |
Help -Save Session Copy- to WAV error | Graham Bolger | Pro Tools TDM Systems (Mac) | 3 | 12-14-2002 06:07 AM |
disk error 37 on "Save session copy in" | simonchase | Pro Tools TDM Systems (Mac) | 3 | 07-03-2002 02:17 PM |
disk error 37 on "Save session copy in" | simonchase | Pro Tools TDM Systems (Mac) | 0 | 07-03-2002 03:37 AM |
"Save Session Copy In" Disk Error? | Eric Bazilian | Pro Tools TDM Systems (Mac) | 7 | 01-09-2001 12:45 AM |
