writing in midi
Appreciate those who helped me with my edit window problems. Now...When writing in midi (I'm trying to write drum fills) no matter what duration I set for the notes I get a two or three bar length note. Tampering further affects the playback speed. I followed a tutorial faithfully (the guy was overwriting eighths and sixteenths) but I was unable to duplicate his success. I'm using PT first 2019 with a Focusrite. What am I doing wrong?
Re: writing in midi
Check the screen shot to see where to select the default midi note value. While you can't see(because I cropped the shot too much) is that the notes I dropped with the mouse are indeed 16th notes as selected(Grid value is set to 8th notes). Writing drum fills with a mouse is going to be frustrating at best. Using some kind of midi trigger or midi keyboard would allow you to "play in" notes that approach the actual dynamics of a drummer. When I use a trigger pad device(M-Audio Trigger Finger or my current Akai midi keyboard), I configured a bank of trigger pads in pairs(IOW< 2 pads for snare, 2 pads for tom 1, 2 pads for tom 2, 2 pads for tom 3). By using separate pads for left and right fingers(equating to left and right hands of a drummer), I am able to program drum fills that get very close to "real" sounding. If you only have a keyboard, then just pound out with 2 fingers on 2 separate keys to record the note triggers, then drag the notes to the proper notes on the piano roll so you trigger the desired drum sound(s).
Additional points; 1-What VI you use for drum sounds can make a huge difference in the results. 2-Having rudimentary drumming skills makes a lot of difference. 3-if you have no drumming skills, using a drum VI with loops included will improve your results dramatically(EZdrummer and Addictive Drums are 2 reasonably priced plugins that are very easy to use for creating solid drum tracks with no drumming skill)
Re-writing mod wheel/MIDI automation | improvpwnd | Pro Tools 12 | 4 | 12-15-2015 01:11 PM |
Writing midi before bar 1 | anonymoushelpme | Pro Tools 9 | 3 | 02-05-2012 03:32 PM |
Writing automation without deleting MIDI notes | lostsherb88 | Virtual Instruments | 1 | 11-28-2011 05:32 PM |
Writing a MIDI Plug-In | Cro | MIDI | 3 | 01-05-2008 10:15 AM |
midi writing in "staff" view (stave) | shutiri | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 7 | 05-16-2007 06:16 PM |
