Old 09-30-2019, 07:16 AM
Ulf Ulf is offline
Default Recall Track Preset make plugin not work!!!
When I was recalling Track Preset on the next song in the same project. I tried to adjust the highpass filter in Channelstrip (DSP) and lo mid, it looked like it worked but it did not do anything audio wise. Is this a serious bug or am I doing something wrong???
Pro Tools Ultimate 2019.6.0 HDX
Mac Pro 2x3,46 GHz 6-Core OS 10.13.6
System 5 SC264D, CM408x3, CM402, CM401
AM713, MA703, ML530, MC524, FC726
ProTools Ultimate 2019.5, Avid MTRX
Old 09-30-2019, 07:31 AM
JFreak's Avatar
JFreak JFreak is offline
Default Re: Recall Track Preset make plugin not work!!!
You mean Avid ChannelStrip, right?
Does it (not) work like this if you create a fresh session with a new track and instantiate the plugin by hand?
If the behavior is different from loading a template, there might be a bug.
Janne
Old 09-30-2019, 08:31 AM
Ulf Ulf is offline
Avid ChannelStrip, yes! Have not tried in a fresh session yet. But it must be able to recall a channel setup in a session from a album mix. It is so important that we can trust stuff like this when you do recall after clients feedback!
But i will try it in a fresh session when i am finished with this album!
Thanks for Your input!!!
Recall Track Preset on existing tracks xrekcor Pro Tools 2018 3 08-16-2018 03:31 PM
Recall track preset colliderman Pro Tools 2018 0 03-17-2018 06:20 AM
Can't see Channel Strip plugin controls (Track, Preset, Auto Map, Bypass, etc). DJ Hellfire macOS 9 05-09-2015 08:38 AM
Is there a way to make a preset group of plug ins? rockguitarist1255 Pro Tools 10 3 02-08-2012 06:00 PM
Free Recall Notes Plugin!!!!! Kenny Gioia Pro Tools TDM Systems (Mac) 17 09-09-2008 04:47 PM
