Old 02-20-2007, 12:14 AM
Ford Prefect Ford Prefect is offline
Default Which HDD should be the fast one?
Hi folks,
I plan to buy a new HDD for my laptop. I have two already, both to slow. Which one should be the faster one? The system drive or the audio drive?
If both should be a 7200 rpm HDD can I use only one physical HDD and use different "virtuel" disc for system and audio, or is it better to have two physical HDDs?
So long and thanks for all the fish!
Old 02-20-2007, 12:45 AM
spkguitar's Avatar
Default Re: Which HDD should be the fast one?
The audio drive needs to spin at 7200rpm. You don't need to replace a drive in your laptop, though (I would imagine that would be expensive). All you need is an external firewire drive.
Old 02-20-2007, 04:28 AM
The only reason for me to replace one HDD is to stay flexible for transport. I am a little bit lacy
Old 02-20-2007, 05:47 AM
It is highly recommended to have two physical HDDs.
Obsidian Dragon
Model Name: MacBook Pro
Model Identifier: MacBookPro14,3
Processor Name: Intel Core i7
Processor Speed: 3.1 GHz
Number of Processors: 1
Total Number of Cores: 4
L2 Cache (per Core): 256 KB
L3 Cache: 8 MB
Memory: 16 GB
MacOS 10.15.7 running Protools 2020.12
Old 02-20-2007, 12:40 PM
Which external drives with Oxford chip are recommended? I found Maxtor and Macpower Icecube. Can I use a 6 pin firewire HDD with my 4 pin plug on the laptop? I know that the two more pins are for power supply. Are there cables with 4pin to 6pin plugs?
Old 02-20-2007, 06:08 PM
Yes you can use a 6 pin firewire HDD with my 4 pin plug on the laptop. There are cables with 4pin to 6pin plugs readily available. You will need to provide power to the HDD via a power supply.
Obsidian Dragon
L3 Cache: 8 MB
Memory: 16 GB
Old 02-21-2007, 01:55 AM
UK RAF UK RAF is offline
I have recorded several hours of 16 tracks of 16/44.1k audio on my laptop HDD (5400 rpm) without a hitch.
Digi002/PT 7.3.1
Shuttle XPC SB61G2: P4 (2.8GHz), 1Gb RAM, 80Gb SP0812N (System), 160Gb SP1614N (Data), DVDRW, NVidia 7600GS
Old 02-21-2007, 04:14 AM
Stiff Stiff is offline
Watch out though, the computer I had before this one got hot as hell when I replaced the internal hard drive which basically led to the fan starting to spin way too much and thus causing a lot of noise. I don't know about you, but I for one don't want that when dealing with audio
Daily news & reviews
www.ProToolerBlog.com
New PT10 User. MBox3, MAudio Fast Track Ultra, MAudio Fast Track 8R? epu Pro Tools 10 3 06-13-2012 04:55 PM
is a g5 mac 1.8 ghz fast enough for pt benjaminflam81 Pro Tools TDM Systems (Mac) 2 01-18-2009 06:48 AM
need help FAST SublimeAndy 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 03-02-2005 06:10 PM
Need your help fast! Mark_Knecht 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 10-04-2002 01:41 AM
WAY too fast!! scottgreiner Tips & Tricks 6 08-26-2002 06:44 AM
