  #1781
Old 08-19-2009, 12:19 PM
themadarchitect themadarchitect is offline
Default Re: i7 Builds - Specs and Results
ok so I've read just about every post my eyes could handle this week in this thread...
Other than page 136, did anyone ever get the chance to post a step by step instruction for the most stable i7 build? was just curious...cause I'm ordering parts today.
  #1782
Old 08-19-2009, 03:47 PM
Keybeeetsss's Avatar
Keybeeetsss Keybeeetsss is offline
Hey man.. I figured som1 would hav chimed in by now..(I've been on my phone here for the last couple hrs) anywayz, actually just take a look @ our builds on the 1st page... I think all of our builds have been stable... Its not necessarily gonna be a MOST STABLE build for the most part b/c any user error can cause the supposed MOST STABLE build to tumble easily ...
MYSPACE ON'EIM
LAUTEN MICS & ME
DA'TUBE ON'EIM
'IS TAMARA HOME'
NO, SHE'S WITH
HOBO KEY
'' (that dopey green thing)
('we' must start using pronouns)
  #1783
Old 08-19-2009, 09:13 PM
recordingguy recordingguy is offline
Here are my specs, after years of no errors with ptle 7.4 on a core 2 duo, I upgraded to PTLE8 and a new i7 desktop. Now I get the increase your buffer error when I do that later I get the decrease your buffer. Here is the report...
I have only 1 video card installed. report shows 2.
Same hardrives from my last protools desktop.
using Digi002R
Thanks in advance.
SiSoftware Sandra
Computer
Model : Gigabyte EX58-UD3R
Workgroup : WORKGROUPS
Host Name : ptcpu
User : d-nizzle
Processor
Model : Intel(R) Core(TM) i7 CPU 920 @ 2.67GHz
Speed : 2.8GHz
Cores per Processor : 4 Unit(s)
Threads per Core : 2 Unit(s)
Type : Quad-Core
Integrated Data Cache : 4x 32kB, Synchronous, Write-Thru, 8-way, 64 byte line size, 2 threads sharing
L2 On-board Cache : 4x 256kB, ECC, Synchronous, ATC, 8-way, 64 byte line size, 2 threads sharing
L3 On-board Cache : 8MB, ECC, Synchronous, ATC, 16-way, Exclusive, 64 byte line size, 8 threads sharing
Computer
Mainboard : Gigabyte EX58-UD3R
BIOS : Award (Phoenix) FB 05/04/2009
Bus(es) : X-Bus PCI PCIe IMB USB FireWire/1394 i2c/SMBus
Multi-Processor (MP) Support : No
Multi-Processor Advanced PIC (APIC) : Yes
Total Memory : 3.25GB DDR3
Chipset
Model : Giga-Byte X58 I/O Hub
Front Side Bus Speed : 2x 2.4GHz (4.79GHz)
Chipset
Model : Giga-Byte Core CPU Generic Non-Core Registers
Total Memory : 6GB DDR3
Memory Bus Speed : 2x 532MHz (1GHz)
Memory Module(s)
Memory Module : Patriot Memory 1333EL Series 2GB DIMM DDR3 PC3-10700U DDR3-1334 (7-7-7-20 4-27-8-4)
Video System
Video Adapter : ATI Radeon HD 4350 (40 SP 600MHz, 1GB DDR3 2x400MHz, PCIe 2.00 x16)
Graphics Processor
Adapter : ATI Radeon HD 4350 (40SP 600MHz, 1GB 400MHz)
Storage Devices
WDC WD4000AAJS-00YFA0 (400GB, SATA300, 3.5", 7200rpm, NCQ, 8MB Cache) : 373GB (D:)
WDC WD2500JS-22NCB1 (250GB, SATA300, 3.5", 7200rpm, NCQ, 8MB Cache) : 233GB (C:)
Hitachi HDT721010SLA360 (1TB, SATA300, 3.5", 7200rpm, NCQ, 15MB Cache) : 932GB (F:)
ATAPI iHAS324 A (SATA150, DVD+-RW, CD-RW, 2MB Cache) : N/A (E:)
Logical Storage Devices
Hard Disk (C:) : 228GB (NTFS) @ WDC WD2500JS-22NCB1 (250GB, SATA300, 3.5", 7200rpm, NCQ, 8MB Cache)
1TB (F:) : 932GB (NTFS) @ Hitachi HDT721010SLA360 (1TB, SATA300, 3.5", 7200rpm, NCQ, 15MB Cache)
WD400G (D:) : 373GB (NTFS) @ WDC WD4000AAJS-00YFA0 (400GB, SATA300, 3.5", 7200rpm, NCQ, 8MB Cache)
Optical Drive (E:) : N/A @ ATAPI iHAS324 A (SATA150, DVD+-RW, CD-RW, 2MB Cache)
3.5" 1.44MB (A:) : N/A
Peripherals
LPC Hub Controller 1 : Giga-Byte LPC Interface Controller
LPC Legacy Controller 1 : ITE IT8720F
Audio Device : Giga-Byte HD Audio Controller
Audio Device : PC Partner R700 Audio Device [Radeon HD 4000 Series]
Serial Port(s) : 1
Disk Controller : Giga-Byte 4 port SATA IDE Controller
Disk Controller : Giga-Byte 2 port SATA IDE Controller
Disk Controller : Giga-Byte JMB36X PCIE-to-SATAII/IDE RAID Controller
USB Controller 1 : Giga-Byte USB UHCI Controller #4
USB Controller 2 : Giga-Byte USB UHCI Controller #5
USB Controller 3 : Giga-Byte USB UHCI Controller #6
USB Controller 4 : Giga-Byte USB EHCI Controller #2
USB Controller 5 : Giga-Byte USB UHCI Controller #1
USB Controller 6 : Giga-Byte USB UHCI Controller #2
USB Controller 7 : Giga-Byte USB UHCI Controller #3
USB Controller 8 : Giga-Byte USB EHCI Controller #1
FireWire/1394 Controller 1 : Giga-Byte TSB43AB23 1394a-2000 OHCI PHY/link-layer Controller
SMBus/i2c Controller 1 : Intel 801xx/63xx SMBus
Printers and Faxes
Printer : Microsoft XPS Document Writer (600x600, Colour)
Network Services
Power Management
Mains (AC) Line Status : On-Line
Operating System
Windows System : Microsoft Windows XP Professional 5.01.2600 (Service Pack 3)
Platform Compliance : x86
recordingguy
Recording Guy's Studio & Sound
www.recordingguy.com
Cedar Rapids, IA
  #1784
Old 08-19-2009, 09:28 PM
philip888's Avatar
philip888 philip888 is offline
Disable the Audio in the BIOS.
Gigabyte EX58A-UD3R BIOS FH, Intel Core i7 CPU 980X, 24GB Mushkin Enhanced Blackline DDR3 1600Mhz PC3-12800, NVIDIA GeForce GTX 560, Windows 10 Pro 64 Bit, Pro Tools 12.4 Antelope Orion 32
  #1785
Old 08-19-2009, 09:29 PM
Okayyyy recordingguy(& sorry phillip but disabling audio doesn't have much if anything to do with the problem honestly)... We meant look so see what we were referring to... the things we told u in ur thread aren't gonna change... Just sayin that basically we've given u ur answer & problems, but as always, everyone wants to proclaim how it worked fine with bla bla bla, which was the reason for u to come here & see WHY we said the things u say worked with bla bla bla are not & will not work now... So again, Ur video card & definitely ur drives ARE ur problem & will remain the problem as long as u stay w/the "it worked fine" attitude...
U might call me an arse but @ the end of the day, I/we have pointed u out the problems... Only said come here b/c ur so persistent about what worked before & so u can understand the i7 rig & why what worked before is now irrelevant...
MYSPACE ON'EIM
LAUTEN MICS & ME
DA'TUBE ON'EIM
'IS TAMARA HOME'
NO, SHE'S WITH
HOBO KEY
  #1786
Old 08-19-2009, 09:35 PM
mykhal c's Avatar
mykhal c mykhal c is offline
using Digi002R
Thanks in advance.
Video System
Graphics Processor
Storage Devices
as others said in your other thread...culprits are probably video card and hdds. memory architecture is totally different on the i7 compared to your C2D. the QPI controller is sittin' there waitin' on your hdds. the C2D just does not have that kinda thru-put...PERIOD!!! and video card for all the reasons that have been explained a gazillion times here. more onboard ram on vid card the more it takes away from the OS. lastly, just make sure your ram is in triple channel mode
bassist...deep pocketz anyone???!!!
The Basschakra Lucid Soul Trip
HDNative | Omni | i7-3930K OC'd 4.0GHZ |
ASUS X79 Sabertooth | 32GB GSkill DDR3 2133 ram | mo' stuff
  #1787
Old 08-19-2009, 09:38 PM
We try ta tell he, but he notta lissen
MYSPACE ON'EIM
LAUTEN MICS & ME
DA'TUBE ON'EIM
'IS TAMARA HOME'
NO, SHE'S WITH
HOBO KEY
  #1788
Old 08-19-2009, 09:42 PM
philip888's Avatar
Yes make sure your RAM is in triple channel mode.
Your RAM should take up Slots 1, 3 and 4. That is from left to right.
  #1789
Old 08-19-2009, 09:45 PM
philip888's Avatar
You makin me hungry fo some "grits" now.
  #1790
Old 08-19-2009, 09:54 PM
FRUIT SNACKS with that?
MYSPACE ON'EIM
LAUTEN MICS & ME
DA'TUBE ON'EIM
'IS TAMARA HOME'
NO, SHE'S WITH
HOBO KEY
Best Core 2 Series Desktops-Results and Specs sunburst79 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2416 02-19-2013 07:49 PM
new to pc builds chazc080488 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 11 10-18-2011 07:10 PM
any p45 builds fofif5792 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 09-09-2008 12:47 PM
OSX "builds" Richard Barrie Pro Tools TDM Systems (Mac) 2 10-18-2004 08:37 AM
