Plugin Automatically Disables itself ???
I have a track in record ready.
I have an amp simulator plugin on that track. I can hear-and-audition the amp simulator as long as the transport is stopped. But, once the transports starts rolling, the plugin automatically puts itself into Bypass. Apparently, I have accidentally check-or-unchecked something to cause this to happen. Your support, please. thanks,
27" iMac; 32gigRam; OSX Catalina 10.15.2; PT 2019.12.0; Apollo x8p; UAD-2-Satellite-TB3-Octo; |
Re: Plugin Automatically Disables itself ???
Things to try:
1-disable automation on that track(just in case there is some accidental automation at work) 2-make sure LLM is off(Low Latency Monitoring at the bottom of the Options menu) 3-Make sure you are not in Input Only mode(the green I button should be off) This is all shooting in the dark. If none of it helps, come back with some details(interface, plugin, OS, etc)
plugin Automatically bypasses itself ???
LLM will bypass the plugin when in record ready mode, regardless of whether the transport is rolling or not, so I don’t think it’s that.
Checking automation as Albee said is a good suggestion. You didn’t address anything he wrote, so we don’t know if you’ve ruled that out. TBH - I’ve come across a setting that does that. I would just trash preferences and go from there. In theory, that would remove any setting you may have inadvertently enabled. Sent from my iPhone using Tapatalk |
Artist Control opens plugin automatically. | sixstringbob | Artist Series | 8 | 02-21-2022 05:43 PM |
plugin that disables itself | cozy_man | macOS | 0 | 01-27-2012 02:48 AM |
How do I automatically insert a plugin on all tracks at the same time? | Undertones | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 3 | 06-29-2010 01:21 AM |
Who disables Widgets? | Dopamine | Pro Tools TDM Systems (Mac) | 2 | 10-30-2008 06:11 AM |
PT 7.4.1 |Automatically Disables Spotlight on Leopard 10.5.2 | 25ghosts | Pro Tools TDM Systems (Mac) | 4 | 02-19-2008 12:37 PM |
